Backup Lights - Brighter Bulbs?
Old Nov 9, 2006 | 02:02 PM
ccds's Avatar
ccds
Default halogen replacemnt bulbs
I have been monitoring the back up lights for the past month and have not
had any sign of over heating. I am very focused on not leaving the car
in reverse for an extended period of time. I think if the lights were left on
for a long time it could damage the plastic housing or the plastic lens.
I am the only one that drives this vehicle so I know that the longest reverse
time is only about 25 sec. that I back out of the drive way.
I will continue to monitor the heat issue and see what the result is and post
the results here a bit later.
If anyone has questions I do have pictures of the modification and the bulbs
and I would be glad to share that info.
you can email me at ccds22@gmail.com
Old Nov 11, 2006 | 07:25 PM
tkrussell's Avatar
tkrussell
ccds,
Do you have a part number and source for the 50W halogen bulbs?
Thanks
Thomas
Old Nov 18, 2006 | 07:24 PM
ccds's Avatar
ccds
Default lpart number
yes I think I still have the info
I should be able to get it for you tomorrow
sorry about the delay in answering, I have be away
Old Nov 20, 2006 | 04:56 AM
ccds's Avatar
ccds
Default part number
HI
I took the bulbs out of the package when I was working on the replacement
so I only have the bulbs left. It says on the bulb 50w 12v Rona.
That is all I could find. I bought 2 sets one was Rona and one set was
Philps. I used the Philps bulbs although they looked exactly the same.
The bulbs are used in garden lighting systems.
I will try to stop by the store and get the number for you
hope this helps
Old Nov 21, 2006 | 05:43 PM
tkrussell's Avatar
tkrussell
Thanks for the info.
I appreciate your help.
If you can find a part number, that would be great.
Thomas
Old Nov 21, 2006 | 07:14 PM
ccds's Avatar
ccds
Default email
Hi
tkrussell send me an email and I will send you pictures of the bulbs and the modification
ccds22@gmail.com
Old Nov 24, 2006 | 06:51 PM
ccds's Avatar
ccds
Default Don't Change To These Bulbs!!!!!!
Hi folks
Just thought I better let everyone know NOT to do this modification to your backup lights.
After 4 or 5 weeks of using the 50W Halogen bulbs I had problems today!
The bulbs melted the plastic housing and caused the main system fuse to
blow. This shut everything down I had to get towed to Lexus for repairs.
Lexus was very good about the mod and fixed it at no charge.
Great service. I told them it wasn't Lexus fault and I should pay for the
repairs but they insisted it was ok and no charge.
What can you say Lexus service is outstanding.
Old Nov 26, 2006 | 06:00 AM
Lil4X's Avatar
Lil4X
Out of Warranty
Yikes!! I was about to try this!
Weak backup lights and a neighbor's Thanksgiving guest backing out of his driveway, dropping a wheel off the driveway and into the ditch, had several of us out Thursday night trying to drag a shiny new Caliber stuck frame down back on the pavement.
Although my driveway's wide, the end segment, thanks to city replacement is blacktop that neatly matches the blacktop of the street . . . and invisible at night. I thought changing those lamps might help - especially if they are only going to be on for twenty-thirty seconds. Having seen the results of backing into a black hole, I was about to make a run to the hardware store. Sorry about your problem, but your post just helped at least one member dodge a bullet!
Old Nov 26, 2006 | 07:11 AM
cheap_deal's Avatar
cheap_deal
its really good to know the dealer fixed the lights and did the replacements free of charge!!! way to go lexus.
Old Nov 26, 2006 | 07:13 AM
ccds's Avatar
ccds
Default Glad to Help
Glad I saved you the aggravation I went through and it was all my
own fault.
Could have been worse....you can get over a little embarrassment....
Old Mar 19, 2007 | 02:41 PM
bigcal's Avatar
bigcal
Help!!! Bought new RX350 December/06. Now have 10,000 miles on it many of which are put on during night hours. Tight spots, poor lighting makes safe reverse driving nearly impossible with the very poor provided back up lights. Add snow and an ice covered camera lens and it is impossible. After reading all the forum on this subject one would think it is time for Lexus to have a recall or at least offer an updated package. I have called several dealers, spoke with parts departments and service managers and none of them will even admit there is a problem. Enjoy the car, bought it with the purpose of necessary driving in poor weather. Great car for going forward during poor weather night time hours, just do not back up.
Old Mar 19, 2007 | 02:52 PM
biff44's Avatar
biff44
The solution probably involves a white LED lightbulb replacement. They put out a lot more light for the same DC current/wattage, so you will not be blowing a fuse or melting the bezel. Does anyone know the bulb number for the backup light, and the wattage. I will try to cross reference it.
Something like this, but the correct socket type, would probably do the trick:
http://www.amazon.com/DODGE-Dakota-b.../dp/B000LOUGK4
Old Mar 20, 2007 | 10:57 AM
bigcal's Avatar
bigcal
Appreciate your response. One of the problems, and I have had several engineer types stand in back of the vechicle, is the direction of how the light is focused. On a dark night, even if the side mirrors are not iced up, it is impossible to see anything on the sides. The lights seem to be only focused for the camera and not at all to the sides. Believe they should leave the present lights as they are but add two more back up lights in the bumper just above the running tail lights. They could use the same light housing only change the lens to white (LCD or ???). It would look OK. Hate to add aftermarket unless they look like they belong.
Old Mar 20, 2007 | 01:34 PM
Lil4X's Avatar
Lil4X
Out of Warranty
The light output may be sufficient depending on your driveway. Mine's a loooong asphalt one that's black as the pit - even in the camera. Fortunately the driveway's two lanes wide, so a put a pair of little solar lights at the far end and just aim between them. About 10pm the solar lights poop out, so if you're making a late run to the store, you're sorta on your own . . .
Next time I resurface the drive, I'm going to sweep a lot of cement over the surface which will lighten it considerably.
Old Mar 20, 2007 | 02:05 PM
bigcal's Avatar
bigcal
Default Back up lights
Problem: Frequently in areas at night, where there is zero light and seldom the same area. I need adequate back up lights on the RX350 or need to always carry a passenger who carries a good portable flood light that does not mind gettin out in a cold, rainy or snowy dark night to light the way behind me.
