2009 rx p/s power window
Old May 15, 2026 | 12:26 PM
uksparky's Avatar
uksparky
Default 2009 rx p/s power window
I noticed from the drivers door switch panel the p/s front window does not work neither does the on off switch push button....window works if i push the button in the p/s door....the other windows all work...i have done the relearn thing ..window half way down..then up pushing switch when closed....this all started few weeks ago...no i didnt replace battery...thanks
Old May 15, 2026 | 02:22 PM
MattRX's Avatar
MattRX
I would pull out the window switch and inspect connector and make sure it is clipped in, something similar happened to my friend's 07 recently. I just pulled the switch out, unplugged and plugged back in, re-learned and everything worked fine after. The pins might have worked themselves loose over the years. If not, maybe try a scrapyard window switch or do some electrical diag on the connector and see if power is going through it properly. Can probably find some diagrams on Toyota TIS if not easily available
Old May 15, 2026 | 08:17 PM
uksparky's Avatar
uksparky
Thanks Matt...i double checked the master switch is ok, all the lights on the switches are on.. windows all click when up exept for the p/s front...looks like its the switch
Old May 16, 2026 | 05:47 PM
uksparky's Avatar
uksparky
Ok let me rewrite this as I screwed up...with ignition on power switch pushed down only stops the rear windows working along with the p/s front, drivers works...start engine all windows working except for P/s front with switch up or down
clemnlem14
RX - 3rd Gen (2010-2015)
Sep 28, 2022 02:04 PM
matts6887
Jan 14, 2021 06:44 AM
Cobra611
Aug 10, 2018 09:05 AM
motiv8rnc
Apr 5, 2014 04:49 PM
