Plugged 2004 RX Roof Drains
Old Dec 20, 2025 | 08:25 AM
C7Stingray's Avatar
C7Stingray
1st Gear
Default Plugged 2004 RX Roof Drains
Rocker panels plugged with leaves, acorn chips, dirt. Any easy fix or known anyone in central NJ to fix. Want to sell but want fixed first. 60,000 miles one owner
Old Dec 20, 2025 | 10:33 AM
Clutchless's Avatar
Clutchless
Any repair shop or body shop knows how to clear clogged door drains or clogged sunroof drains. These problems are common to every car made depending on where it is parked.
The front sunroof drains do not lead to the rocker panels so you may have multiple issues. The front drains are in the front corners and can be cleared with weed Wacker line as shown on many YouTube videos.
The rear drains are more complicated as the rear cargo area side panels have to be pulled to get at the hoses, separate them and clear them.
If the door drains are clogged they may have to remove the inner door panel, but every repair shop, or body shop knows how to do this.
You can use this database to start your search for a local shop, then finish it by checking on Google if they are still around as some of the reviews are old. These are shops recommended by listeners of the Car Talk Radio Show. You can search by city and state.
https://www.cartalk.com/mechanics-files
iizbor3d
RX - 4th Gen (2016-2022)
Aug 15, 2022 03:52 PM
Legolas2
Feb 5, 2016 04:12 PM
srashid
Sep 19, 2006 05:54 PM
