RX330 Can Bus Broken
Old Dec 2, 2025 | 06:05 AM
Bamber's Avatar
Bamber
1st Gear
Default RX330 Can Bus Broken
Greetings! I'm hoping that someone may be able to provide some insight into this issue.
My car is a 2006 Japanese Toyota Harrier which I believe is the same as the RX330. It's an old car but I like it; being old allows me to tinker with it.
Due to certain issues that I have been having, which I will explain below, I had been checking the can bus via the OBD connector with a scope. Voltage levels look good with CANH (yellow), CANL(Blue) and Math being CANL-CANH in red. (my mistake - forgot to switch the operators, it should have been CANH - CANL.)
Anyway, the screenshot I got is below, with a zoomed version in the second image.
The frame shown appears to me to be non standard as compared to other vehicles and devices I've checked but I'm not sure. However, the other issues I'm having include
  • Unable to retrieve data via VCX Nano and TechStream
  • Unable to retrieve data via ELM327. This used to be able to work.
  • Engine & VSC lights permanently on.
  • Suspension a bit stiff(?)
Initially, I was concerned that being unable to retrieve data was due to the DLC3 connector itself but I now believe that not to be the case especially after looking at the screenshots. I think there is something wrong with the can bus and that this may also be affecting the VSC and ABS unit and possibly the suspension.
If you have any suggestions for trouble shooting this issue, I'd be very grateful. My initial thought was to look at J/C1 and J/C2 but I've had some trouble identifying them... The connectors in the Japanese service manuals appear to be different and I don't know why that is.
Anyway, hoping someone can help out.
Thanks.
CANH (Yellow) CANL (Blue) CANL - CANH (Red) (Should be CANH - CANL. My mistake)
[img alt="Zoomed
CANH (Yellow)
CANL (Blue)
CANL - CANH (Red) (Should be CANH - CANL)"]https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/005_31f39d61afd64bd1e434ed96b1af997a6822feb5.jpg[/img]
Zoomed CANH (Yellow) CANL (Blue) CANL - CANH (Red) (Should be CANH - CANL)
File Type: mov
SargeISF
IS F (2008-2014)
48
Apr 2, 2013 08:19 PM
tsachiti
Oct 14, 2011 01:35 PM
Hellomello
CL of Southern California
21
Nov 25, 2008 09:06 PM
Hellomello
Nov 19, 2008 09:07 AM
JIMMY540i.com
Aug 25, 2007 02:03 PM
