Australian parts source.
Old Oct 11, 2025 | 12:46 AM
MickQueensland's Avatar
MickQueensland
Default Australian parts source.
I am in the market for new shocks for a 2005 RX330.
Any recommendatiins for an Australian source.
I want to maintain as close as possible to the original ride, not interested in track day options.
Old Oct 11, 2025 | 03:45 PM
Tomr1951's Avatar
Tomr1951
1st Gear
rockauto.com ship to australia kyb shocks are the go
Old Oct 11, 2025 | 05:09 PM
MickQueensland
Thank you, I am hoping to find something a bit closer. But I will keep Rockauto in mind.
Old Oct 12, 2025 | 02:04 PM
MickQueensland
Rock Ayto are not listing the KYB shocks as an option for my 2005 Japan made RX330
Old Oct 12, 2025 | 03:01 PM
tomr51's Avatar
tomr51
lexus 2005 rx330 has kyb shockies 2005 LEXUS RX330 3.3L V6 Shock / Strut | RockAuto check the part numbers
Old Oct 12, 2025 | 05:56 PM
MickQueensland
Thankyou for the link, those shocks confused me when the add says except air suspension.
I will look for a part number on mine.
thanks again.
Mick
Old Oct 12, 2025 | 06:14 PM
Leeper's Avatar
Leeper
KYB 334394, 334395, 334399, 334400 I just installed those on my 2004 RX330
Old Oct 12, 2025 | 06:26 PM
RofH's Avatar
RofH
This link might help you
Toyota LEXUS RX Car & Auto OEM Parts | 42409
Old Oct 12, 2025 | 08:13 PM
MickQueensland
thank you
Old Oct 12, 2025 | 08:14 PM
MickQueensland
Originally Posted by RofH
Thank you
Old Oct 13, 2025 | 10:41 PM
MickQueensland
Leeper, just so I understand. You changed the shocks only not the entire strut assembly?
Old Oct 14, 2025 | 06:18 AM
Leeper's Avatar
Leeper
Semi correct.... I changed the "Strut" (part numbers given above) as well as the strut boots as they were torn, I did not change the springs nor the shock mounts. My car has 174K miles on it two of the struts were leaking oil (shot).
Installation - To do so required me to use a spring compressor which several auto parts stores here in the US will loan you free. Many say these compresors are dangerous, I did not find that the case however they did require use of my impact gun to compress them.... removal and reinstall of the strut assemblies was easy, removing and replacing the spring on each strut was not so easy but doable. There's several YouTube vides that show how to do this.... pay close attention to the alignment of the arrows and make sure everything is properly set as one of mine the top hat was not on right, rattled badly when hitting a bump, so I had to uninstall and re-use the spring compresor to get it all set.
Good luck
Old Oct 14, 2025 | 04:27 PM
MickQueensland
Thanks Leeper, much appreciated.
Old Oct 15, 2025 | 04:01 PM
MickQueensland
Using the parts numbers above I see that delivered from Rockauto to Australia the shocks will cost me about $1000. Australian.
Buying the same parts here my best quote has been $1498. So Rockauto wins hands down from that point of view, but when I dissassemble the existing strut and remove the leaking shocks, what if other parts are worse for wear.?
Would it be sensible to buy complete strut assemblies and if that is the case what ones would you recommend as I cannot find ones built around a KYB shock absorber.
Thanks for you thoughts on this.
Mick
Old Oct 15, 2025 | 08:18 PM
tomr51's Avatar
tomr51
quick struts are cheap crap kyb do not have them
