What is this wire /harness for?
Old Oct 26, 2024 | 05:52 PM
Blamb330's Avatar
Blamb330
10th Gear
Default What is this wire /harness for?
I can’t tell if something is missing here or if something should be bolted in or something should be connected to this loose wire
Is somehrhing supposed to bolt in here ??
Does this connect to something??
Old Oct 26, 2024 | 08:00 PM
Mesquite77's Avatar
Mesquite77
Its a ground. Someone has done work in the area and forgot to attach it. See where it reaches to and look for an impression of it.
Old Oct 27, 2024 | 11:37 AM
Buzzltyr57's Avatar
Buzzltyr57
On my 07 RX350 it is in a hole directly behing the oil filler cap - maybe 3/4 of an inch away from the cap.
Old Oct 28, 2024 | 12:01 PM
Mesquite77's Avatar
Mesquite77
Like Buzz says, 2008 RX350 below, but your pic is different, so maybe it is a 3.3L RX330. If it is a 3.3L, then when timing belt was changed last time it was just forgotten or mechanic lost the small bolt. Likely does not matter at all.
Old Oct 29, 2024 | 08:57 AM
tammap's Avatar
tammap
Ground points at the front and rear of the engine ED & EE are very important, it could affect your engine performance. Re-attach the ground eye-let at the arrow.
You
need to clean the ground wire with the green crust corrosion at the thermostat housing bolt and tighten the power steering reservoir pressure hose. It is loose.
Old Oct 29, 2024 | 07:45 PM
Blamb330's Avatar
Blamb330
10th Gear
Default Repair references
Thanks!!!!
im trying to figure out the best resource for looking this kind of thing up
I’ve found
RepairSurge.com
$29/1year
Mitchell1
https://www.eautorepair.net/marketin...utorepair.html
$40/1year
AutoZone links to:
https://www.alldata.com/diy-us/en/fi...plan?vid=39547
$60/1 year
Chilton repair book at my library
ChiltonDIY online(need library subscription access)
lexusTech
https://techinfo.toyota.com/techInfo...ent%20Examples
2 days $25
1 month 95
1 year $505
Old Oct 30, 2024 | 06:40 AM
dwb3dwb4's Avatar
dwb3dwb4
1st Gear
Try this site as well for a resource: you can purchase and download the manual for most vehicles. There is a discount code available too- I have purchased for 3 so far, and they have been accurate. Plus, once purchased, it's yours.
https://www.emanualonline.com/
Old Nov 3, 2024 | 08:32 AM
tammap's Avatar
tammap
For Lexus, Toyota and Scion.
1. https://techinfo.toyota.com/
2. https://my.alldata.com/
https://www.identifix.com/
3. https://www.eautorepair.net
And the rest!
Old Nov 5, 2024 | 07:20 PM
Blamb330's Avatar
Blamb330
10th Gear
Default Repair reference resources
I got the chilton book from library but feel like it’s a little light—- mostly on giving context for where the pics of whatever they’re referencing are.
I feel like I’ve seen a few references to the Alldata resource; any preference or reason to consider techinfo.toyota.com even if it is more expensive.
Im probably not going to do anything more crazy that changing a few filters/oil/ maybe brakes, and I’ve noticed some electrical wonkiness for power windows….
Old Nov 6, 2024 | 11:31 PM
vincero's Avatar
vincero
10th Gear
[QUOTE=Mesquite77;11809788]它是一個地面。有人在該區域做過工作但忘記附上它。看看它到達
哪裡
I think so, too.
Old Nov 7, 2024 | 01:31 PM
tammap's Avatar
tammap
In this case, there is no need to spend money on the service manual.
One of us at Club Lexus will be able to help you with that.
Halloween10
Jun 19, 2024 09:51 AM
optimistic
Sep 28, 2023 11:22 PM
Jasaveli
May 20, 2022 08:45 PM
benxd
Dec 23, 2016 08:42 PM
kikaida
Sep 25, 2007 05:31 PM
