Afs off light flashing
Old Aug 6, 2024 | 01:51 PM
toonkev667's Avatar
toonkev667
Default Afs off light flashing
Afs off light flashing starting from two weeks ago.what parts should I replace and how much would it cost? Thanks guys
Old Aug 6, 2024 | 02:42 PM
evident's Avatar
evident
Could be multiple things. check the ride height sensor near the rear right side of your wheel. if it's all rusted out you might need a new sensor or assembly. Aftermarket ones work fine from rockauto. If that doesn't work, you may need a new swivel motor that's on either headlight. Do you have an advanced OBD II scanner? you will get specific codes that can help you isolate the issue.
Old Aug 6, 2024 | 03:41 PM
toonkev667's Avatar
toonkev667
I have ancel scanner not sure if it's obd two. Which scanner would you recommend for detailed issues like this? If there is affordable I would be happy to purchase one.
Old Aug 6, 2024 | 04:51 PM
evident's Avatar
evident
does it fit into your obd ii port? I would plug it in and see what codes you get. I have an Xtool D8 which is kind of pricey but you can get cheaper ones.
Amazon.com: XTOOL D8S Bidirectional Scan Tool 2024 Upgraded Ver. of D8 Scanner, OBD2 Scanner Diagnostic Tool, Topology Mapping, ECU Coding, 38+ Resets, CAN FD & DoIP, All System Scanner for Car with 3-Year Update : Automotive Amazon.com: XTOOL D8S Bidirectional Scan Tool 2024 Upgraded Ver. of D8 Scanner, OBD2 Scanner Diagnostic Tool, Topology Mapping, ECU Coding, 38+ Resets, CAN FD & DoIP, All System Scanner for Car with 3-Year Update : Automotive
Old Aug 6, 2024 | 06:30 PM
toonkev667's Avatar
toonkev667
is there any budget friendly one just by any chance? 100 to 300 is also okay
Old Aug 6, 2024 | 08:49 PM
Leeper's Avatar
Leeper
I bought the techstream cable from Amazon or eBay came with the software too, think I paid @$30? Works perfectly on my windows 10 laptop.
Nov 21, 2023 08:53 PM
chavezdel
May 14, 2008 08:04 PM
