Tpms warning flashing after sensor replacement
Old Aug 5, 2024 | 03:19 PM
toonkev667's Avatar
toonkev667
Default Tpms warning flashing after sensor replacement
I recently got my tpms sensors replaced from tyre shop and tpms light is still flashing even after the tyre guy programmed it. What should I do? Thanks guys
Old Aug 6, 2024 | 08:23 AM
Felix's Avatar
Felix
I wouldn't have left. Did he check them to figure out which one waa bad or just replaced all of them? Don't forget about the spare & did he check the air pressure?
Old Aug 6, 2024 | 09:29 AM
toonkev667's Avatar
toonkev667
He only replaced the one that was low in battery and rest he said it was okay. Do we need the tpms for spare as well? The guy said there shouldn't be any tpms sensor in the spare tyre
Old Aug 6, 2024 | 11:58 AM
Mesquite77's Avatar
Mesquite77
The spare tire does have a TPMS.
Also, TPMS sensors need to be registered, and some 3td party ones must also first need to be programmed, some do not. 2 separate things.
Old Aug 6, 2024 | 01:49 PM
toonkev667's Avatar
toonkev667
Can it ever be disabled by any chance?
Old Aug 6, 2024 | 07:11 PM
lexo98's Avatar
lexo98
Make sure the main/2nd tpms switch is in the correct position if it has one. A lot of shops don’t get the light to turn off before you leave and say just drive it. That doesn’t always work. Go back and have them reprogram the ECU and without turning the car off rescan each sensor so that they send a confirmation signal to the ECU. They may also need to clear any DTC codes after that if the light stays on. If all that doesn’t work you may also need to drive it.
Old Aug 7, 2024 | 06:30 AM
Felix's Avatar
Felix
Originally Posted by lexo98
Make sure the main/2nd tpms switch is in the correct position if it has one. A lot of shops don’t get the light to turn off before you leave and say just drive it. That doesn’t always work. Go back and have them reprogram the ECU and without turning the car off rescan each sensor >>> Including the spare tire) so that they send a confirmation signal to the ECU. They may also need to clear any DTC codes after that if the light stays on. If all that doesn’t work you may also need to drive it.
Old Aug 7, 2024 | 06:36 AM
toonkev667's Avatar
toonkev667
So should i make them put it on main or 2nd? Thanks
Old Aug 7, 2024 | 08:29 AM
lexo98's Avatar
lexo98
I would just put it in main.
Old Aug 11, 2024 | 02:38 PM
Felix's Avatar
Felix
This^^^^^ as the 2nd option is for swapping winter tire/wheel assemblies.
Lx3232
Jan 9, 2026 07:36 PM
CoFo
Sep 20, 2023 01:44 PM
Kostyan
RX - 3rd Gen (2010-2015)
Dec 28, 2022 03:38 PM
cyberfist0
Nov 8, 2020 02:27 PM
test_accou
May 13, 2017 12:01 PM
