Rx400h new wheels offset question
Old May 9, 2024 | 11:53 AM
LatinUnit's Avatar
LatinUnit
3rd Gear
Question Rx400h new wheels offset question
Just wondering if the following 18" wheels fit my rx400h 2008? I get confused on the offse and wheel width combination.
CRUIZE BLADE
OFFSET
32 Front & 35 Rear
WHEEL WIDTH
8.5 Front & 9.5 Rear
Old May 9, 2024 | 01:27 PM
MattRX's Avatar
MattRX
Cutting it close w/ the offset but it may fit. 8" rim with 30 offset on my car barely clears. Those are staggered rims too so you'd need to run a wider tire out back like 245 or 255 up front and 275 in the back. No point running staggered on a non-RWD car
Old May 9, 2024 | 01:32 PM
Leeper's Avatar
Leeper
Even worse if your car is a 2wd then it is front wheel drive and staggered would be crazy
Old May 12, 2024 | 07:28 AM
Felix's Avatar
Felix
Pass on those offset spec's as well as the two different widths...... For a 8.5'' width, go w/ a 10mm offset as that'd get the tire/wheel assembly flush w/ the fenders.... A 235-55x 18 tire fits great on a 8.5'' wheel & you can go w/ a 255-55x18 tire as well. .......For a 9.5'' wheel, Get a 0 offset wheel. The critical clearence if the section width of the tire to the rear strut clearence........For the 9.5'' wheel,, you can go w/ a 255-55x18 tire which clears the front when turning. I'd go w/ a 295-45x18 tires thou........A 255 is 29'' tall & a 235 is 28.1'' & a 295 is in the middle at 28.5''. I'm running 9.5'' w/ 295-45x18's..........Another upgrade is going w/ the gen3 bbk.......Rotors, pads & a pr of reman calipers is a direct bolt on......A quick look at the gen2 pads compared to a the gen3 pads tells you as well as going to a 2 piston caliper form a single piston caliper.....
RC5
RC F (2015-present)
23
Apr 19, 2019 05:24 AM
tlk2megoos
May 30, 2016 10:40 PM
sgmbab
Sep 6, 2012 07:47 AM
jbone29
Jun 6, 2012 07:09 AM
