2005 RX330 Headlights
Old Oct 20, 2023 | 11:54 AM
Daverx2005's Avatar
Daverx2005
4th Gear
Default 2005 RX330 Headlights
My RX330 has AFS system. I’ve changed the headlights out with non AFS headlights. All good, but how do I disable the flashing AFS dash light? I don’t see a AFS fuse.
Old Oct 20, 2023 | 12:07 PM
ericg's Avatar
ericg
Looks like the AFS is part of a larger circuit fed by fuse 52 as per this link. So if you pull fuse 52, other circuits will be affected.
https://www.autogenius.info/lexus-rx...e-box-diagram/
Old Oct 20, 2023 | 01:12 PM
Daverx2005's Avatar
Daverx2005
4th Gear
Any other option?
Old Oct 20, 2023 | 02:46 PM
ericg's Avatar
ericg
I don’t believe so. Someone with more experience may respond but the network bus will never get a satisfactory signal from the AFS module which will continue to show as a fault.
Old Jun 2, 2024 | 05:58 PM
JoeF77's Avatar
JoeF77
10th Gear
what was the process to change them out since the wiring is different ?
Old Jun 2, 2024 | 11:56 PM
Daverx2005's Avatar
Daverx2005
4th Gear
Lexus has connectors to match the 2 needed connections. The other one I taped off. Very easy to change back to the AFS.
Old Jun 3, 2024 | 04:27 AM
JoeF77's Avatar
JoeF77
10th Gear
where can I find the part or what would the description be for me to look it up ?
Old Jun 3, 2024 | 01:14 PM
Daverx2005's Avatar
Daverx2005
4th Gear
Any Lexus or Toyota parts Dept. can pull up a diagram for the connections you need. They order it for you, then you go to O’Reillys get the adapter for the bulb. Connect the 2 and you got it.
Old Jun 4, 2024 | 02:03 PM
cfh13427's Avatar
cfh13427
Just a last ditch idea- You could remove the dash light bulb for the AFS indicator!
Like I said, it's something to think about until you get it Resolved, Hopefully You can get this Resolved and Not have to Remove the AFS Indicator bulb!
rclab1
Jan 26, 2024 05:43 AM
vincity
IS - 1st Gen (2001-2005)
Oct 15, 2018 02:04 AM
sean9975
May 29, 2008 04:39 PM
