engine flush
Old Mar 19, 2023 | 09:59 AM
1mark's Avatar
1mark
Default engine flush
Is it save to use engine flush before an oil change?
Old Mar 19, 2023 | 12:24 PM
spinellib's Avatar
spinellib
Yes, but I would use a quality product and follow the directions. I don't think the "flush" products do harm, but not sure they do any good.
For instance, old timers like to use Marvel Mystery Oil in the crankcase before an oil change. Modern engines don't need or like products such as MMO or Seafoam.
Fuel Treatment is good. You might be better off just using some Redline Complete Fuel System Cleaner or Gumout Multi System Tune Up. Both products contain PEA, a powerful chemical solvent for breaking down and dissolving carbon. If you'd like, you can even dump some of the Gumout into the oil and run the car for a bit before changing the oil.
So if you do want to "flush" your engine, I'd recommend the Gumout Multi System or Gumout All In One Complete Fuel System Cleaner.
Do both if you want. Dump a bottle in the fuel tank, and another bottle in the oil.
Old Mar 19, 2023 | 12:42 PM
cdnewton's Avatar
cdnewton
What makes you think you need an engine flush? Has the vehicle been neglected? Do you change your oil regularly? Do you use the proper API certified oil? Lots of questions.
Old Mar 19, 2023 | 02:09 PM
1mark's Avatar
1mark
Oil change every 3k
New filter
Oil looks clean not dark on the dipstick.
Just on some cold start ups I hear a valve rattle for a moment or two.
Old Mar 19, 2023 | 02:59 PM
tomr51's Avatar
tomr51
rattle is "normal". if the car has been well maintained, i would not do a flush. sometimes they can do more harm than good
Old Mar 19, 2023 | 03:32 PM
1mark's Avatar
1mark
Thanks, I was looking for the normal information
Old Mar 21, 2023 | 02:15 PM
Felix's Avatar
Felix
If you want to add chemicals to clean your rings/lifters, I'd drain a few qtrs & add 2-4 qtrs of atf & drive it easy for a day or two.
I'd use a good synthetic oil & filter.....
Old Mar 21, 2023 | 09:54 PM
iMSQ's Avatar
iMSQ
No issues with the engine? Just do regular oil+filter changes. No chemicals.
Harleygirl
Aug 31, 2022 07:17 AM
jdanielca
Oct 26, 2018 11:43 AM
bearbrew
RX - 1st Gen (1999-2003)
Jul 16, 2010 07:20 AM
Larry99
Feb 22, 2004 07:37 AM
