Help identify please
Old Aug 3, 2022 | 11:54 AM
maxSteel's Avatar
maxSteel
Originally Posted by Lizzie1228
Thank you for taking the time to clarify that for me. I really appreciate it. I'm kind of under the impression that I may need to change the gasket and the spark plug o-rings. That's the only reason I would need a torquing wrench. Like I said I paid $1,300 to have the gasket replaced which stopped the oil leak. I also paid to have the spark plugs replaced then 8 months later I have check engine lights on in the car is stalling. Pulled a coil and a spark plug and discovered oil on the spark plug. Along with the orange stuff around the top of the coil. Maybe he did not do the gasket right or maybe he didn't replace the o rings or maybe I have a hairline crack in one of the coils. Either way I can't imagine messing it up any more than he did for $200.
I'm not a mechanic but I can follow directions and I'm an artist. I will have help also. I have the parts. Do you think it would be better just to have somebody else do it or should I give it a try. I'm getting quotes for $600 just to do the spark plugs. Do you have any idea what a good estimate of having the repair done if I have the gasket spark plugs and coils already.?
I understand you're not liable if you tell me to try to get a bit to try 😁
$600 to do the plugs sounds like they are pricing in removing the intake, but you can change the rear plugs without removing it.
You didn't mention if you had oil fouling in the front, back, or both.
If only the fronts had oil fouling the front valve cover is easy. If it's the back the intake has to come off, it's not super hard but you will need a bigger tool set.
I would still suggest given your skill level and tools just start with removing and cleaning the fronts to get a feel for it before moving to the back ones.
Clear codes, swap coils to see if problems move, and so on. It's quick and easy and good experience for a novice.
Old Aug 16, 2022 | 07:01 AM
Lizzie1228's Avatar
Lizzie1228
9th Gear
I just wanted to let everyone know that replied to this post. I had a gentleman come over who knew a little bit about cars. I explained to him what was going on. He took out the coils in the front and move them around. He ended up putting a new spark plug and a new coil in Bank 2(the far left front one if you're looking at the car). I didn't have a code reader so I took it to O'Reilly's and the guy that worked there scan the codes before he cleared them and said it came up misfire 2 possibly 4 can't remember for sure on the second one. This guy knew a lot about what he was talking about. I proceeded to ask him why he didn't work on cars and he said he didn't like it. He cleared the codes and I am going to drive it around close by for a couple days to see if it comes back on. The check engine light that is. It did go from blinking to solid before I had the codes checked. He said it was going to come back on it might take a couple days. Could this have all been fixed by just replacing one coil? I have a feeling not but it sure would be nice. Just asking for an opinion if anybody feels like it. Ty.
Old Aug 16, 2022 | 08:32 AM
maxSteel's Avatar
maxSteel
Thanks for the update.
One bad coil is enough, that's why the advice was to clear the codes and diagnose the first one that is reported.
Old Aug 16, 2022 | 09:44 AM
salimshah's Avatar
salimshah
25 Year Member
The technique is tracing by swapping. You should have a code reader as that helps in diagnosis. Old times, the mechanic would remove one by one the spark plug wire to zero in to the failing cylinder.
Once you know the failing cylinder number, the variables are spark-plug and ignition coil. You swap each with a good cylinder and if the problem moves then that part is the failing part. If you have multiple fails then more investigation is needed.
Salim
Old Aug 16, 2022 | 11:02 AM
Margate330's Avatar
Margate330
Default Need a code reader
Originally Posted by salimshah
...You should have a code reader as that helps in diagnosis.
Boom!
Smashing that like button.
I say it over and over.
If you are serious about DIY you need your own code reader, preferably one that shows live data too.
You can get better help in the forum because you will have accurate data to report such as in this case seeing what code pops up when swapping coils, flying blind without it.
Plus as an added bonus you have the convenience to scan anytime needed.
Bigsackjak
Feb 14, 2021 10:13 AM
scutch
Dec 28, 2019 07:50 PM
Gil Smash
Sep 16, 2014 07:10 PM
plocke82
Maintenance
May 2, 2009 11:16 PM
surflife5
Performance
Oct 23, 2006 06:50 AM
