Engine and Transmission Mount
Old Mar 2, 2020 | 08:56 AM
MellonC00's Avatar
MellonC00
Default Engine and Transmission Mount
Is there a quick visual check I can do to see if my engine and transmission mounts need to be replaced? I have over 250K miles and never worried about my mounts until recently when my Mercedes mounts went bad in about 80K miles. It was a quick reminder that I needed to check mine. Can I crawl under the car and check it out or do I need to take it to a shop?
Old Mar 2, 2020 | 11:31 PM
Australian's Avatar
Australian
My guess is the rubber in your bushes rotted in your old but low mile Mercedes. The easiest way to tell is look at the motor running is it bouncing around then you need new mounts. If the engine moves when engaging gears you need new mounts. I do have new mounts at about 150k I changed mine.
Old Mar 3, 2020 | 04:33 PM
Margate330's Avatar
Margate330
True this...
Only like to add is easiest with a helper to put car in Drive and Reverse and another person to inspect.
I probably replaced too many top dog bone mounts to count- they failed regularly especially on domestic cars and are usually the first ones to go.
PS- Replaced all mine this year at 151k Miles due to bad vibration.
MellonC00
Jul 25, 2019 11:32 AM
ksultan78
Oct 22, 2014 06:05 PM
2jzgttegs
Feb 18, 2013 06:36 AM
djpolak
May 8, 2009 09:24 PM
dkinzer
Nov 26, 2008 07:51 PM
