RX300 ignition key, ECU?
This youtuber claim that this method will work with older Toyota. You can try to verify if it does work. I don't know if it really works. I have a copy of Techstream that will allow me to erase all the registered key and will register the current key in the ignition lock.
https://www.youtube.com/watch?v=QocuEYNE6KM
I have not seen any vin info written to any ecu from 1998-2002. I have replaced the ecu in my LX470 with 4 different ecus while experimenting and never have seen any vin info. i have seen vin info written to ecus for vehicles after 2002
Yes, the chips i have been giving away are 93c56 eeprom.
I want to order a few new chips but I don't want to get the wrong brand. In my search it's a bit confusing because there's letters following the 93c56. There's questions regarding 16 bit or 8 bit an I'm a bit hazy on it all. Would you be good enough to post a link for the correct one? I was also hoping to find a socket for the chip so I don't have to heat it up or solder leads to it while flashing it. Given my limited knowledge, I don't know what the proper name of the eprom socket, so perhaps you can help shed some light on it. Thanks again
Understood. Thank you much for previous helpful input in this space.
Kadrian21
Mar 9, 2017 10:32 PM
63Galaxie
Oct 27, 2016 02:50 PM
Kadrian87
Sep 22, 2016 04:24 PM
