Jerking transmission and blinking check engine light causing poor engine performance
Old Nov 30, 2018 | 06:41 PM
Julius2323's Avatar
Julius2323
Default Jerking transmission and blinking check engine light causing poor engine performance
I have a 2003 Lexus RX 300 with 182,000 miles. Recently bought from the auction and I’ve had issues with since purchase. Transmission jerks from 2nd to 3rd if you’re not at exactly 2000 rpm and engine has recently began performing badly with shaking at idle when in drive and when reversing. I’m going to get it checked out once I get back home but wondered if anyone had the same issue. I’m assuming it’s a misfire due to faulty fuel injectors because I’ve never had more than 15mpg average since owning vehicle.
Old Nov 30, 2018 | 07:33 PM
salimshah's Avatar
salimshah
25 Year Member
Does your CEL light come on during self test [the first time you turn the key from ACC to RUN]?
When the engine is running does the CEL light up? If so what codes show up when you connect the RX to OBDII reader?
Salim
Old Nov 30, 2018 | 08:21 PM
Julius2323's Avatar
Julius2323
Salim
Yes it does and yes it lights up and blinks repeatedly for about a 30 seconds then goes solid but I haven’t gotten back home yet to get the codes checked.
Old Dec 1, 2018 | 06:43 AM
salimshah's Avatar
salimshah
25 Year Member
That is most likely misfire.
Timing, spark plugs, ignition coils are suspect.
Plugs are supposed to be changed at 110K miles. Make sure you only buy OEM. Timing belt 90K [I would also replace roller/tensioner and check water pump]
The question you have to deal with is ... what would you spend to do the basic stuff and then be ready to spend more on things you might keep finding more. But I guess, you knew that, when you bought the vehicle from auction.
Salim
Flat Spin
Jun 9, 2021 01:30 PM
tashrhicks
Jul 23, 2018 07:03 PM
vivawafs
Oct 26, 2015 01:11 PM
clevercat
Jul 7, 2009 06:39 AM
