Compass isn't working?
Old Nov 22, 2018 | 08:21 PM
gookies's Avatar
gookies
Default Compass isn't working?
Anyone ever had this problem? There is nothing in the top right corner display, I've tried searching and the only ones I've seen are ones who needed theirs recalibrated and had a "--" or "00" display, mine has nothing. I've looked at the fuse box diagrams and don't see anything pertaining to the compass.
Old Nov 22, 2018 | 09:07 PM
salimshah's Avatar
salimshah
25 Year Member
search found this for me. Hope it helps
http://www.lexomans.com/manguide-538.html
Salim
Old Nov 23, 2018 | 03:01 PM
gookies's Avatar
gookies
Salim
Tried turning it on (holding AUTO for 3 seconds), but nothing, seems like it's dead; I thought there might be a fuse for it, but I don't see any labels on the fuse diagram pointing to this.
Old Nov 25, 2018 | 05:58 AM
salimshah's Avatar
salimshah
25 Year Member
Time to dig out wiring diagram.
My hunch is it shares the 12v with the mirror dimmer circuit. Does the green light up for you?
Salim
Old Nov 25, 2018 | 09:39 AM
gookies's Avatar
gookies
Salim
Nope, no green light either. Not that big of a deal though, I was just hoping someone else had this problem and it ended up being a simple fix.
Old Nov 25, 2018 | 02:45 PM
salimshah's Avatar
salimshah
25 Year Member
Sorry we dont carry the schematic diagram on site due to copyrights. Outside search will very likely find you the circuit diagram.
You can also just test out every fuse. Problem is there are fusible links which you can trace through the circuit diagram (and part locator diagram).
In desperation you can remove the mirror and see if the plug is hooked up or even check the voltage at the connector.
Salim
3GSLEXUS
Feb 25, 2021 03:09 AM
project350
Nov 4, 2016 09:13 AM
gtstcactus
Feb 15, 2014 03:04 AM
SC1984
Mar 14, 2011 01:05 PM
forksports
May 11, 2005 11:55 PM
