IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
O2 codes wont go away
Old Sep 10, 2013 | 12:03 PM
tauzins's Avatar
tauzins
Default O2 codes wont go away
Ok so ive been having code issues with my o2s for about 4 months now, ive replaced o2's and spark plugs and just cleaned my MAF and ran seafoam through the system but codes p0130, p0150, p0133 and p0153 keep coming back... now after i did the spark plugs these codes went away but now they are back again....
In addition to cleaning the MAF and using seafoam... my abs light now rapidly flashes...
163k miles on the car with timing belt alrdy done. and all regular maitnance finished like it should be
im lost on what else it could be. any help would be great
Thanks, tauzins
Old Sep 24, 2013 | 08:40 PM
timIS300's Avatar
timIS300
I received very similar codes when I first purchased my car. The CEL light was on and the indication was the Catalytic Converter based on the codes I was receiving. I attempted to use known working O2 sensors in all of the bunges on the Cats and the codes continued to be thrown. I decided the next course of action was to replace the Catalytic Converters, as there are 2, or three I can't remember, of them. Once I did this and used Spark Plug Defoulers to trick my ECU into a correct reading the issue went away.
I can't say that this is exactly what is wrong with your car, but if you truly want to find out take it to Lexus and have them run some tests on it. Or, do some research online and see what others are saying. I found the internet to be a valuable tool when trying to figure out the course of action.
guilty117
GS - 1st Gen (1993-1997)
Jun 20, 2017 12:44 PM
blackbutee
Oct 6, 2013 05:49 PM
yeskay
Mar 4, 2013 05:25 PM
defo
RX - 1st Gen (1999-2003)
Jun 26, 2012 11:58 AM
BlacBeaute
Nov 27, 2011 10:22 PM
