Battery Running Down After Non Use
Old Jan 26, 2018 | 07:34 AM
toshiyori's Avatar
toshiyori
Default Battery Running Down After Non Use
We have a RX 330, 2003 model, We do not use the car very often, after it set's for a week I have to charge the battery to get it started.
What normal battery load does this model have to drain a battery when the unit is not in use ?
Old Jan 26, 2018 | 09:08 AM
salimshah's Avatar
salimshah
25 Year Member
When battery is strong and no accessory is left running and every bulb is turned off, the battery should last 3-4 weeks.
Now if your charging system is weak, or you dont drive enough [where the start and use (discharge) is more than the aggregate charge] then it can go bad in a day or two.
Have the battery tested and the charging system tested [alternator bench test is very conclusive].
Then invest in battery tender [about $5 from harbor freight with coupon]. Plug this once a week (or more frequently).
You may like to search on Parasitic draw if you are after some real numbers.
Salim
worker
Mar 22, 2025 02:26 AM
OldLs400
Apr 4, 2019 01:31 PM
txrse58
Aug 22, 2013 10:24 PM
genijet
Sep 28, 2008 01:46 AM
gurjot
Jul 1, 2008 04:49 PM
