ac clutch relay
ac clutch relay
Hi everyone just signed up.Had my wifes 02 lexus rx 300 motor removed to install rear main seal,When i got it back the ac wasn't very cold noticed clutch would kick on and cut off.I can't get a reading on pressure because compressor won,t run long enough.Does anyone know where fan clutch relay is, can't find it in relay box.A picture of or diagram would be great.Thanks for help in advance
I would start with the shop who did the rear-main seal.
For proper diagnosis you do need to monitor both the low and high. To charge, you need to fill the low to the recommended low side pressure.
Salim
