Differential oil replacement
Old Apr 23, 2003 | 09:45 PM
whitels's Avatar
whitels
Default Differential oil replacement
I have looked but cannot find the fill hole for the differential fluid on a FWD RX300. Anybody?
Old Apr 24, 2003 | 02:03 PM
ederny's Avatar
ederny
Default white, I don't have specifics on the RX yet...
...but here is some info that may give you some ideas:
http://lexusmodz.netfirms.com/GS_DIY...iff/index.html
Old Apr 24, 2003 | 02:59 PM
whitels's Avatar
whitels
Thanks. I will try to look again (although I understand that info is for the GS).
Old May 22, 2003 | 10:23 AM
MarvinCNG's Avatar
MarvinCNG
Default Transaxle
The RX300 FWD (and also the AWD) have a 'Transaxle' : ie the Transmission and front differential are combined. I went thru this process recently.
There are TWO drain plugs underneath: one in a conventional horizontal plane, and one set vertically under a large cylindrical casting set on edge (probably the Planetary gear for the front diff).
(Gawd, a picture would be worth several thousand words here...)
The fill is thru the auto trans dipstick, just like a conventional automatic.
However, it doesn't normally need to be changed. Ever. And the auto trans dipstick is so marked.
If you do, remember to use Toyota T-4 fluid ONLY.....it was $11 / quart at my local Toyota dealer. I shudder to think what Lexus would charge.....
FYI On the AWD version, there is a Transfer case that DOES require fluid change (at 30K I think).
Old May 30, 2003 | 08:57 PM
gp1200x's Avatar
gp1200x
Use a synthetic gear lube...like AMSOIL or Mobile one. I couldn't find Mobile one in the exact oil weight but it was close. Mine has not leaked in the front or back.....as others on the board thought it could with a synthetic gear lube. I have checked every few thousand miles and the seals are holding fine. 85K on my RX
Old May 30, 2003 | 09:02 PM
gp1200x's Avatar
gp1200x
Almost forgot....It is very hard to fill the cases unless you can pump it in....very difficult to get the gear lube in since you cannot just pour it in.. There is no room above the case to hold the container. I had to use a long tube and slowly let it drain down in while wedging the container in a wheel well. It took an hour or two to fill but it worked. Make sure you fill it too and clean off the metal filings from the bottom bolt.
Old Jun 1, 2003 | 12:23 AM
MarvinCNG's Avatar
MarvinCNG
Just to clarify: You *are* talking about the 'Transfer Case' (AWD only) here, right ?
That does take SAE 85/90 Gear Lube, and as you say, is a bear to fill.
The original poster asked about the Front Differential, which is combined with the Auto transmission. Takes ATF.
Just don't want anyone to mix 'em up.....
autodriver
Nov 20, 2018 05:25 PM
LocalIS300
IS - 1st Gen (2001-2005)
Jun 29, 2015 03:36 PM
pilot2
Feb 12, 2015 09:28 AM
autodriver
Jun 30, 2004 10:29 PM
whitels
Maintenance
May 10, 2003 12:58 PM
