rubber engine support
Old Jan 28, 2014 | 02:03 PM
edupim's Avatar
edupim
Default rubber engine support
hi, doing a inspecyion i found the engine support with gap
i m showing with a screwdriver just to show.
my question is. is it normal or i have to change this support
below the photos
Attached Thumbnails rubber engine support-2014-01-26-14.27.42.jpg   rubber engine support-2014-01-26-14.27.58.jpg   rubber engine support-2014-01-26-14.28.13.jpg   rubber engine support-2014-01-26-14.28.46.jpg
Old Jan 28, 2014 | 02:17 PM
2GSKaizen's Avatar
2GSKaizen
The mount on those top 3 pictures is fine. When those mounts start going bad they tear the rubber between the top "V" shaped metal plate, and that bottom "W" shaped metal plate. That suspension arm in the last picture is completely trashed. That is so bad it's a safety concern. Get a new one before it falls off!
Old Jan 28, 2014 | 02:23 PM
edupim's Avatar
edupim
ok thank you a lot .
do you know if it is possible to change only the mount or i have to change all suspension arm
do you know the part 'name to buy in amazon
thanks again
Old Jan 29, 2014 | 06:53 AM
Lexmex's Avatar
Lexmex
thanks again
The suspension arm is one unit, you can't replace that one bad round bushing you see there.
Old Jan 29, 2014 | 07:52 AM
edupim's Avatar
edupim
good advise.
People in ebay sells only the bushing
here in brasil they installs using strong pressure and say (rthat is it 'have a nice trip")
JTex
Jul 31, 2024 02:05 PM
Mike246
Aug 22, 2018 12:54 PM
Kal333
Jul 28, 2018 11:29 AM
maxbreaker
18
May 14, 2008 01:55 PM
ESES
22
Feb 27, 2003 11:21 AM
