1999 RX300 side step
Old Oct 24, 2013 | 06:37 PM
Lexusblack's Avatar
Lexusblack
Default 1999 RX300 side step
Hi Everyone, I need advice tin setting up the side step on my 1999 lexus rx300. Any advice on installing it. I couldn't find any information on it. Any advice or photos will be great.
Old Oct 24, 2013 | 08:22 PM
trhs75's Avatar
trhs75
If I were you, I would first hold the step up close to where it is to be installed. See if the mounting holes correspond to bolt locations underneath the car. I would guess most of these steps and bars install without drilling and using existing bolts. Depending on the thickness of the brackets, you may need to get slightly longer bolts than what are there now. This might be a place to start, anyway.
Old Oct 25, 2013 | 05:04 AM
2KHarrier's Avatar
2KHarrier
If it will help, I can shoot a photo of my installation, from the underside...
Old Oct 25, 2013 | 07:38 AM
Lexusblack's Avatar
Lexusblack
That would be great if you can provide some photos of your installation. Greatly appreciated.
Old Oct 25, 2013 | 09:59 AM
salimshah's Avatar
salimshah
25 Year Member
Each installation is going to be different, unless you have the same step.
Salim
Old Oct 25, 2013 | 12:43 PM
jerwong's Avatar
jerwong
Usually the manufacturer will provide instructions. I installed on one a Jeep before but not on my Lexus. Make sure you torque the bolts on properly (assuming manufacturer provides torque values) as vibration over time may cause uneven bolts to loosen.
Old Oct 26, 2013 | 04:35 PM
2KHarrier's Avatar
2KHarrier
Default Pictures
Sorry in the delay on posting pics.
Here's what I have. Probably was done by the dealer back in 2000.
bungle6621
Sep 7, 2018 12:36 PM
Xavier56
Jul 31, 2018 09:15 AM
RXRider13
May 19, 2014 07:39 AM
HarrierAWD
Maintenance
Jan 1, 2003 04:30 PM
Ruslan
Sep 27, 2001 10:09 PM
