Dead Battery...again.
I went to start the car this morning, and nothing. Dead battery. Again.
So maybe the alternator is at fault?
Or, perhaps it's the Grom Bluetooth adapter I installed nearly two weeks ago? I followed the instructions Grom provided me, as well as the CL write-up for the same device (e.g., plug the Grom unit into the CD wiring harness). The Grom is working fine, but perhaps it's parasitically drawing current from the battery when the car is turned off?
Advice? Ideas?
Tomorrow, I'll take the RX to a shop that specializes in Toyota/Lexus ($100/hour for labor) if I can't figure it out before then. They've worked on my car before.
Are you sure nothing was left on?
There is any easy DIY check to see if you have anything draining your battery.
Connect a volt meter to you battery and start pulling fuses one at a time. If you see a small jump in voltage when you pull a given fuse, you can narrow down your drain to a single circuit.
I realize this post is old, however someone else with a battery issues may find this helpful if they do a search.
