Oil Change Question
Old Aug 10, 2013 | 05:28 AM
MtnDweller's Avatar
MtnDweller
Default Oil Change Question
When we purchased our 2001 RX 300 it had 160,800 miles on it. And it was serviced at our local Toyota dealership.
Did some research at lexus.com and found out that at 30,190 miles, it had "PSTN W/PIN,OR ROD,RING (ALL) R&R ** WARRANTY OPCODE **" and "CRNKSHFT &/OR CRNKSHFT BRNG R&R" performed.
The time is approaching for us to do our first oil change and my question is this: Knowing about the sludge issue these vehicles have and based upon this post https://www.clublexus.com/forums/4797937-post2.html in this thread https://www.clublexus.com/forums/rx-...il-change.html would it be wise to run an engine flush since I have no idea if there's sludge in there or not?
We checked the oil a few days ago just to make sure the engine isn't burning it and the level hasn't changed any and the oil is amazingly clean. We plan on using synthetic from here on out.
Tina
Old Aug 10, 2013 | 06:39 AM
hypervish's Avatar
hypervish
No, at that many miles leave it alone. I'm not a big fan of engine flushes anyways, they seem to cause more harm.
If you are really curious about sludge pop the front valve cover open and check.
How many miles did you run this oil? If it didn't consume any, then that's a good sign. Usually with sludge build-up, you consume a lot of oil.
Old Aug 10, 2013 | 06:47 AM
MtnDweller's Avatar
MtnDweller
That was my thoughts also, but wanted to be sure.
4000 miles. Going to change it this weekend.
Thanks for your help.
Old Aug 10, 2013 | 07:37 AM
thomas1's Avatar
thomas1
Many, as I have found the Castrol 0-30 weight German European synthetic oil does a great job of cleaning the engine. After I switch to that oil I even noticed that the crust under the oil fill cap disappeared.
Old Aug 11, 2013 | 12:17 AM
code58's Avatar
code58
Thomas, I don't have to tell you, if that crust disappeared, that is some powerful stuff. That crust under the cap is like granite!
Old Aug 11, 2013 | 06:26 AM
hypervish's Avatar
hypervish
The crust disappeared on mine as well using PP 5W-30. However, I suspect it was due to age rather than the oil.
German Castrol 0W-30 only has a TBN of 9.7, while Pennzoil Platinum has a TBN of 12.3
The higher the TBN the better, it's essentially what takes care of all of the acids in the engine. Keep in mind, TBN is not the only thing that keeps the engine clean, but it is one of the most important.
This is why I'm a big fan of PP, especially in this application. Helps keep the engine remarkably clean!
Old Aug 11, 2013 | 07:28 AM
thomas1's Avatar
thomas1
I would also like to note that not only did the crust go away, but the engine was noticeably smoother.....Never seen anything like that.
Old Aug 11, 2013 | 09:57 AM
MtnDweller's Avatar
MtnDweller
Hey Thomas, I wasn't asking which oil to use. I was asking about a pre-oil change engine flush.
Old Aug 11, 2013 | 02:52 PM
salimshah's Avatar
salimshah
25 Year Member
Sorry for interrupting ,,,
You are getting 2 for 1 with the recommendation .. a cleanser and lubrication oil. You will be amazed within 3 oil changes.
Salim
Old Aug 12, 2013 | 12:44 AM
code58's Avatar
code58
I have had experience with it and would never recommend it. (engine flush, at any time) Products like Auto-RX, Castrol Synthetic (German), Pennzoil Platinum (or Pennzoil Ultra) remove the deposits, but not by a flush. They slowly dissolve the deposits and then the deposits (in liquid suspension in the oil) are drained with the oil change. Flushes (if the chemicals are powerful) break the junk all loose at once, it clogs the pick-up screen and oil starvation is the end result. Your new replacement engine should run great for a long time with proper care. (proper oil, change intervals and NO FLUSHES!) LOL
murphysf
Jan 27, 2025 06:44 PM
SilvaIS350
GS F (2016-present)
Jun 3, 2018 09:23 AM
pizdets17
Jun 28, 2011 05:21 PM
funcrusher
Feb 1, 2011 07:21 PM
McMuffin
Jan 6, 2008 07:33 PM
