Code 1135
Old Aug 8, 2013 | 11:07 PM
gphilemon's Avatar
gphilemon
Default Code 1135
Any help out there, My rx300 2001 has no heat, CEL and VSC lights on with code 1135
Old Aug 9, 2013 | 12:32 AM
code58's Avatar
code58
The one code you've listed is specific for the heater in the B1S1 (that would be rear, by the firewall) A/F ratio sensor. That failure is common with anywhere from 80-120 thousand miles. It does not likely have anything to do with the other problems. The CEL and VSC lights can come on together with a lot of problems that don't necessarily have anything to do with VSC, they're often just telling you you need to attend to something under the hood. The heater issue may be a blend door motor or a number of other things that can cause no heat but since hot water flows continuously (365 days of the year) it is likely one of the controls or doors in the heater system inside the car.
Old Aug 14, 2013 | 04:45 AM
gphilemon's Avatar
gphilemon
not sure I understand "B1S1" and what do the A/C ratio sensor look like? Picture will help ... thanks code 58
Old Aug 14, 2013 | 06:38 AM
hypervish's Avatar
hypervish
https://www.clublexus.com/forums/rx-...el-sensor.html
Britrx300
Mar 7, 2023 09:56 PM
rmartindc
21
Mar 7, 2023 01:58 PM
tsand1113
Feb 24, 2015 09:59 AM
adamyansam
Mar 14, 2011 07:48 AM
JasonBrods
Oct 12, 2010 08:21 AM
