run time problem
Old 07-07-13, 09:11 AM
lexusrocko
lexusrocko's Avatar
Default run time problem
1999 RX300. Starts and runs fine until I hit about 3200-3500RPM, then it putters and looses power. I have cleaned the MAF, new air filter, checked/replace some small vacuum hoses but it didn't help. Don't think its an ignition problem since it runs okay up to 3500 RPM. Is there anything else a shade tree mechanic like myself can check? Help! and thanks.
Old 07-07-13, 09:14 AM
lexusrocko
lexusrocko's Avatar
Further info. My codes also showed up as P0302,0304,0306 (front cylinders).vacuum leak, fuel system, etc.
Old 07-08-13, 12:29 AM
code58
code58's Avatar
Have you disconnected the battery for about 5 minutes to reset the computer? I don't know if that will do it or not but it's cheap (cost $0.00 and about 5 minutes of your time) and many times cures problems that otherwise have you chasing yoiur tail. Just like shutting down and rebooting your computer.
Old 07-09-13, 02:57 PM
lexusrocko
lexusrocko's Avatar
Tried the battery disconnect and cleaned the MAF again. Car runs great and I can run up to 5000-6000 rpm with no missing for the first 3-4 minutes. Then when the engine heats up, I can't go beyond 3200-3500 without misfiring and losing power. It runs and start so well, but after several minutes I can't rev up the engine without sputtering. Any more ideas? Thanks.
Old 07-09-13, 03:19 PM
salimshah
salimshah's Avatar
Received 1,019 Likes on 919 Posts
Are you getting CEL?
If so what is the code?
Salim
RCM83
IS F (2008-2014)
09-08-13 05:28 AM
coolercity
07-14-13 09:38 AM
CptCrunch
03-06-13 07:50 PM
antnkel
Performance & Maintenance
04-04-10 05:53 PM
her99rx300
13
06-21-06 10:19 AM
Quick Reply: run time problem
