Starting problems
Old Dec 10, 2011 | 06:38 PM
r3dl4b3l's Avatar
r3dl4b3l
Default Starting problems
Hi all,
My 2001 RX300 won't start unless I step on the gas pedal and once it does start and I get off the gas it dies. Is this a starter issue?
Old Dec 10, 2011 | 07:00 PM
amblyn's Avatar
amblyn
Originally Posted by r3dl4b3l
Hi all,
hey, i just replaced my starter, before i did when i turned key would just click 3 turns later would start.
so from experience ill tell you no your starter isn't cause. you say you give it gas and will go, so engines turning over im assuming every time you try to start? tells me starter is doing its job.
any codes? is your check eng light on??
check that your air intake isnt getting blocked.
i think if your fuel filter or pump or injectors were clogged or not doing there job you would def have a check eng light on.
when you do get it on with gas pedal does eng seem to fire norm?
also when you turn key with no gas what happens after like 3 tries??
hope my 2 cent help you out somehow just trying to help you rule out somethings to pin point problem. i thought with newer cars giving it gas while trying to start has no effect but thats just based on my small knowledge of cars let us know some more details and im sure we can get this resolved
Old Dec 10, 2011 | 07:48 PM
carguy07's Avatar
carguy07
Clean your IAC valve.
https://www.clublexus.com/forums/rx-...out-yours.html
Old Dec 10, 2011 | 08:07 PM
hypervish's Avatar
hypervish
Originally Posted by carguy07
x2, while your there clean the throttle body too. Also, not a bad idea to clean out the MAF sensor.
Old Dec 12, 2011 | 10:20 AM
RX300CE's Avatar
RX300CE
clean your IACV, if 2 screws have not been opened before use phillips head screwdriver tap tap tap with hammer to break the bond it will come out easy, here is a link with pictures, thanks tcheung87
https://www.clublexus.com/forums/rx-...-write-up.html
barrynwatt
Jan 4, 2014 08:25 PM
Doc Yota
13
Jun 19, 2013 04:29 PM
TFry
Sep 7, 2012 10:45 PM
echad
GS - 1st Gen (1993-1997)
Jul 19, 2011 11:04 AM
SC30096
Aug 21, 2007 04:37 PM
