Cracked key shell casing - help needed
Old Nov 21, 2014 | 10:44 AM
  #91
Eternity Key's Avatar
Eternity Key
Former Sponsor
Contact Lexus of Queens they offer the Eternity Key
Old Nov 21, 2014 | 11:48 AM
  #92
beachlover's Avatar
beachlover
Originally Posted by iluvny
I find it difficult to believe that any legitimate locksmith would charge $300 to cut a key. That's just crazy.
Agreed. Me thinks they want $38 to cut it and $262 for stuff to smoke while they do it.
BTW, Lexus dealers around me take offense you bought a key off EBay, so won't cut any keys other than their own. Maybe if I offered the key cutting employee cash in person, but I have other options at my disposal.
Old Nov 22, 2014 | 02:15 PM
  #93
maorsela's Avatar
maorsela
To update: Got the key cut @ the local Ace, cost $2.
The key will not turn the switch, when I inspect it, it doesn't look identical.
Here's an issue:
I use the existing key, the ignition turns fine.
When I insert the newly cut key, it doesn't turn the ignition. I remove it.
I can use the newly cut key at the door to lock/unlock, but it will not turn the ignition (ignition switch stuck in 'lock' stage).
I insert the existing working key, and the ignition is locked!!
Any idea what's going on here?
I wiggle the key in the switch for ~30 seconds, then all of a sudden it releases the lock and I can turn on the engine.
I'll just buy a new shell from Amazon/Ebay and have the dealer cut it. Wasted $7...
Old Nov 23, 2014 | 07:15 PM
  #94
Raoul's Avatar
Raoul
I got two keys, cut and delivered for $27. I believe the turnaround was two or three days.
All I had to do was put the old guts in the new shells.
Old Nov 24, 2014 | 03:41 AM
  #95
Cacophony's Avatar
Cacophony
Here's an issue:
When you're trying the new key, do you have the electronics in it? If not, it won't start. Or at least you have to hold the old key (with the electronics) near the ignition.
When I got my key cut, it would turn the ignition, but it was just act like it wasn't getting any gas. But if I held the old key nearby, or put the electronics in the new shell, it would work.
Maybe they just need to run through the cut one more time. Might just be slightly off, especially since you say it doesn't look identical.
Old Nov 24, 2014 | 03:45 AM
  #96
Cacophony's Avatar
Cacophony
Yes, they wanted $100.00 (Smithtown)
Edit: I just called my local locksmith and they charge $38.00
I called a few locksmiths and they were all around $200, I think.
They don't have storefronts anymore. They say they'll come to you and cut the key. I guess that's part of the service charge.
And my dealer wanted at least $50.
I just didn't wanna pay that much for a dumb key, since I already had the electronics.
Old Nov 24, 2014 | 09:33 AM
  #97
shumif1's Avatar
shumif1
$65 for key and cut, any lexus dealer , i went to presige lexus in ramsey nj
Old Nov 28, 2014 | 11:24 AM
  #98
maorsela's Avatar
maorsela
Yeah, i placed the remote inside the new shell. The key won't turn, and will cause the ignition switch get stuck.
I just ordered another shell from Amazon for $5, I'll just get it cut @ the dealer, they charge $25.
Old Dec 1, 2014 | 02:43 PM
  #99
jerwong's Avatar
jerwong
Did you program the car to recognize the key? When I got mine, I had to go through a dance of lock, unlock, lock unlock, turn key, etc before the RX300 would accept the key.
Old Dec 1, 2014 | 02:59 PM
  #100
iluvny's Avatar
iluvny
Probably because you got new electronics with the new key.??
Most people in this thread are swapping the existing electronics over to the new key shell so no programming is necessary
Old Dec 3, 2014 | 02:28 PM
  #101
DewHawk's Avatar
DewHawk
I bought a shell key ($4 online) and switched the chip and then Lexus charged me $22 to cut. But, still much cheaper than a Lexus replacement key.
Old Dec 3, 2014 | 02:41 PM
  #102
Briand_OH's Avatar
Briand_OH
A BTDT, don't want to repeat, but my sister has a 99 RX-300 and a 2004 RX-330. I was driving the latter on mission for airport pickup. I had grabbed a "valet" key in addition to remote key fob. Upon coming out of local bank, I took the valet key and put it in the ignition, and it kinda turned, but not activating starter. Turned out valet key was for RX-300 and it would NOT come out of ignition. Much time and calls ensued and idiot brother hadn't paid AAA, so eventually (hours) a flat bed arrived to tow to dealer (no help on Lexus 800# or two Lexus dealers). Tow guy maintained he could't get onto truck because ignition lock was engaged and left me So....girlfriend drove me the ~40 mile round trip to pick up RX-300 to complete pickup. A local locksmith had idea to lube it with WD-40 (trip to my house) and eventually RX-300 valet key released from RX-330 ignition. Now keys are labeled!
Old Dec 12, 2014 | 08:27 AM
  #103
maorsela's Avatar
maorsela
Got the $5 amazon key cut by Lexus for $25, worked right away. Learned my lesson with the amateurs from Ace Hardware...
2jzdc
Nov 1, 2018 08:37 PM
Dolphin
Canada
Jul 31, 2013 12:34 PM
DY3VERSITY
CL of Southern California
Jul 14, 2012 12:13 PM
Justakid
Maintenance
Jun 24, 2009 06:33 PM
