Tachometer Jumping & Check Engine light on!!
Old 04-28-11, 05:30 PM
lserlohn
lserlohn's Avatar
Default Tachometer Jumping & Check Engine light on!!
Hello all.
Today, when I drove home at highway, I found the check engine light is on. I didn't feel anything wrong, or maybe the acceleration of the car is a little bad. Then after 10 mins driving, I found my tachometer sometimes jumped from 2000 rpm to 4000 rpm, and the car run weak. I stopped at highway, and restarted the engine, after several minutes, it jumped again. When I drove around my local zone at 30 -40 mph, I didn't find anything unusual, but I was afraid.
I don't have the code reader on hand right now, but I am wondering if anybody similar with this problem?
I just got my rear brake pad changed by my friends, is there a chance that he made a mistake or loosen some unwanted parts?
The car's VSC light is also on, but I didn't feel any vibration, like usual. Is this because of VSC??
Today is rain...
Old 04-28-11, 05:37 PM
salimshah
salimshah's Avatar
Received 1,001 Likes on 904 Posts
Have the code read. Without the codes, any diagnosis would be a wild guess.
Brake problem would manifest it self differently ... failure of proper braking or wheel becoming too hot ... [just check if the wheel is hot].
Salim
Old 04-28-11, 05:39 PM
hypervish
hypervish's Avatar
It sounds like overdrive turned off, get the CEL read.
Old 04-29-11, 12:14 PM
lserlohn
lserlohn's Avatar
Post
Hello, I just got my code read. It is P0770, it says Shift Solenoid "E" Malfunction (Shift Solenoid Valve SLU). I attached the document below.
I asked Local repair shop, he said it may be the issue, since my engine speed goes up and down.
I am not sure how serious it is. I found one guy asked the same question, but he didn't fixed it.
Please share with me your most knowledge, thanks very much. My poor RX300
File Type: pdf
Old 04-29-11, 01:41 PM
thomas1
thomas1's Avatar
Are you sure there arent secondary codes...Sounds like Knock sensors to me...That would prevent Tranny going into overdrive.
Old 04-29-11, 02:51 PM
lserlohn
lserlohn's Avatar
yes, the reader shows P0770 01/02
P0770 02/02 P
However, this problem always happens when I climb a bright or hill, but I didn't carry anything heavy.
Old 04-30-11, 06:30 AM
Lexmex
Super Moderator
Lexmex's Avatar
What is your tranny fluid level at...I overfilled mine a tad when I was in Mexico precisely due to the steep hills I would travel every day.
seanmwple
08-23-23 05:44 PM
ry2216
ES - 5th Gen (2007-2012)
10-05-20 10:02 AM
joetarin
04-26-17 06:34 PM
clevercat
07-07-09 06:39 AM
sliva001
SC- 1st Gen (1992-2000)
06-11-07 10:23 PM
Quick Reply: Tachometer Jumping & Check Engine light on!!
