lcd display surround panel
Old May 10, 2002 | 02:28 PM
ukrx300's Avatar
ukrx300
Default lcd display surround panel
Help!
Can anyone tell me how to get the panel surrounding the
LCD display on the dash off . It rattles and squeaks so much
i will felt the rear and replace, but how does it come off?
Old May 13, 2002 | 02:59 PM
VVT-i's Avatar
VVT-i
It's easy. You see the woodtrim around your shifter and carefully pop that out with a small screw driver and try not to damage the wood. There are 6 clips behind it. You have to put the transmission in N or D to clear it when you pop it out.
After that you will see 4- 10mm bolts behind it and take those bolts out. Then you pry on the side of the center vent( there 4 more clips behind it) . You can tape your screwdriver tip to prevent any damage to the dash and woodtrim.
Good luck and I hope you fix the rattle.
Old May 13, 2002 | 03:22 PM
hleo1's Avatar
hleo1
Finally Found my manuals again.
Well, in case you need more help to remove that, I've scanned a page from the manual about removing the center instrument panel ...
Hope this helps...
-Hendry
sjowett
RX - 3rd Gen (2010-2015)
18
Oct 10, 2019 04:39 PM
CosmoLexus
Jun 26, 2018 02:11 PM
ahmed24
Sep 27, 2010 06:37 AM
Neza
Mar 8, 2010 05:00 AM
