Timing Belt question/ engine question
Old Dec 13, 2009 | 05:26 PM
99rx's Avatar
99rx
Question Timing Belt question/ engine question
Hi, i have 85,xxx miles on the car.(1999) Wondering if the rx's are non-interference motors like some camrys i hear about. Just wondering. Let me know. Thanks.
Old Dec 13, 2009 | 05:48 PM
carguy07's Avatar
carguy07
Oh no, here we go again!
It seems that if you have the VVT-i kicked in the answer is yes it is an interference motor. This gets debated a lot though. If it was me I would let it go another 20k or so. The age does not concern me as much as mileage does.
Old Dec 14, 2009 | 03:13 AM
artbuc's Avatar
artbuc
It is definitely, absolutely and without any doubt whatsoever interference. Or, maybe it isn't. No, I'm absolutely sure it is non-interference. Or, maybe it is interference. Oh-oh, now I am only sure of one thing. It is definitely interference or non-interference. Yes, without a doubt it is one or the other.
Old Dec 14, 2009 | 05:05 AM
JAB's Avatar
JAB
Here's an idea, 99rx - you run yours till it breaks, then let us know!
Old Dec 14, 2009 | 10:00 AM
Lexmex's Avatar
Lexmex
It's interference because it's vvt-I, with the I being the difference here.
Old Dec 14, 2009 | 04:36 PM
sktn77a's Avatar
sktn77a
Probably not worth the risk of assuming non-interference, but the timing belts are pretty robust so I wouldn't be paranoid about approaching the magic 90,000 miles!
Old Dec 19, 2009 | 11:35 AM
coastie's Avatar
coastie
Greetings!
Just had the local Toyota dealer replace the TB and accessory belts; $425. He said that they never have to change the pullys and the water pump only rarely and then only if it shows leaks/damage. No oil or coolant leaks, shaft seals all good. I checked out the TB and it looked fine (125,000 miles), flexible and no obvious damage/fraying. The accessory belts each had missing rib sections, but the TB looked AOK.
Merry Christmas!
Old Jan 1, 2010 | 07:50 AM
99rx's Avatar
99rx
Well i thought the I meant Intelligence in this case? VariableValveTiming-Intelligence??
Old Jan 1, 2010 | 09:08 AM
Lexmex's Avatar
Lexmex
Yes it is. I am talking about the fact that having the I (Intelligence) is a way to know its interference.
Old Jan 1, 2010 | 10:41 AM
99rx's Avatar
99rx
oh ok thanks a bunch!
Old Jan 1, 2010 | 11:30 PM
code58's Avatar
code58
Art- does your wife know you're a troublemaker or are you able to keep that to yourself ?... I bet not!
Old Jan 2, 2010 | 02:54 AM
artbuc's Avatar
artbuc
Welcome back Roger! Happy New Year!!
Old Jan 2, 2010 | 10:11 AM
tomstep2's Avatar
tomstep2
Originally Posted by coastie
Greetings!
Merry Christmas!
WHY, WHY, WHY did you not have the pulleys, tensioners, and water pump changed? I made this horrible mistake on my ES (see some of my other postings) and a few months after the belt change, the pulleys went bad (everything was perfect when I did the belt change). I had to pay for the entire job again! Luckily my ES is non-interference so when the pulley seized and the skipped 4 teeth, I was not out an engine. If it was my RX, I would not take the gamble and had the pulleys done. If the same happened on my RX, it would have destroyed the engine.
NOTE TO EVERYONE: Replace all pulleys, tensioners and water pump when your replacing the timing belt! It WILL save you time, money, and possibly an engine in the long run!
Old Jan 2, 2010 | 11:20 AM
karasdad's Avatar
karasdad
absolutely! It's only $250-$300 more to have all the other stuff done. would make it much easier to sell the car later too.
Old Jan 2, 2010 | 04:42 PM
code58's Avatar
code58
Thanks Art- Happy New Year to you (and all the rest on this terrific forum). Spent a couple weeks in Nashville with SIL&BIL and went to GD's Nurses pinning and graduation from college as well as CE & Christmas with all the mid-south states family. Had a great time. Great to see everyone. Back for GD's wedding in May. Hope your Christmas was great and that your family is all doing well.
Roger
