Is starter or ignition switch?
I have a problem with my lexus rx300,when i start the car the starter its not turning off it keip spining.1 time i turn the engine off and the starter keip spining,this problem it is not every day it is once whille.What is it the starter or the ingnition swhitch.Thankyou
I would treat myself to a new starter....Compared to most Lexus prices, this starter is readily available from low cost part stores, and reasonably priced. Considering what's happened, I would think everything is gonna go bad on it. Because I'm sure sometimes it was on, while the motor was running, and you didn't know it....The real cost is the effort and down time to take the starter out. They only have a certain amount of "starts" in them anyways, and if you take care of any vehicle, you can expect to replace it at least once.....
http://www.nationsautoelectric.com/instructions.html
IMHO, your problem is not the contacts of the solenoid [they typically wear out and provide resistive path for the current]. Your problem is either sticky contacts [unlikely] and issue with the release [return spring, deposit on relucter making the solenoid sticky [very likely] or starter pinion not moving back on the motor shaft].
To really diagnose this to the failing part, you will have to pull the starter and check it on the bench.
Chose what is best for you. Sure fix will be to replace the whole starter & solenoid assembly [it can be over kill]. The other extreme, just disassembling the solenoid and a cleaning of reluctor may solve your problem too [just time and your labor].
Salim
Whitenova
17
Jun 4, 2013 06:15 PM
cfuller74
Jul 21, 2008 08:04 AM
