Front Crankshaft Seal Leak
Hey, Can anyone give me some advise on what might be the problem. I have a 01 RX300 that I did the complete timing belt, water pump, and seal replacement. But I can get the front crankshaft seal to stop leaking. I am using OEM parts. I have been putting some oil and tapping it lightly in evenly with the front cover. Any advise would be helpful.
It leaks a slow drip as soon as the engine is started more when the rpm increases. It wasn't leaking but since I was in there for the timing belt I decided to replace it. No miles since I changed it. The car has 110600 miles. I didn't notice a groove but I will check tomorrow. This is driving me crazy. Tomorrow I am planning on getting a seal from a different manufacturer maybe it will seal better.
You need to look very closely where the lip of the seal touches the crankshaft. the faintest line worn into the crankshaft can cause a leak. The good news is there is a device called a bearing sleeve that can be put over the crankshaft end which is basically a very thin sleeve that fits tightly over the worn area. Then install the new a new seal and you will be good to go....
You need to look very closely at the crankshaft surface where the seal lip rides on it.
If there is any kind of groove you can fix it with a crankshaft sleeve that fits very tightly over the cranshaft fixing the groove. Here is one manufacturor, however auto parts stores or machine shops should be able to get you one. Then put a new seal in and you are good to go:
http://www.microsleeve.com/csrs.html
Hey Code58, I agree, my neighbors highlander had a slight wear spot on that 50k engine, I cleaned it up with a emery paper, probably would have sealed fine, just as you did. But the machine shop through a sleeve on the crank. I used one of those on a 87mustang motor where it had extreme wear. Worked great. Some folks call them crankshaft savers.....
That is the seal location on mine. I looked at it today and it does appear to have a faint line where the old seal was rubbing. I will contact microsleeve during the week and get one ordered.
The front cover is not supposed to keep the oil in, so you must trace the source of the leak inside the cover.
Back to the groove on the main shaft. The groove has to be a deposit unless the metal spring cut through the rubber and contacted the shaft. So examine the old seal and if the spring was not exposed .. just use a worn out emry paper to clean out the shaft.
Do not re-use the installed seal and buy a new one. Dip/soak in the brake fluid and glide it into spot.
Good luck
Salim
Good luck
Salim
I hate to tell you this, but rubber with oil contaminated with dirt can cut steel. It does not necessarily have to be a spring wearing thru. I have seen paper cut steel on stuff that I used to work on. Water can cut steel....The front cover contains the seal where the arrow is pointing.
Are you sure you cant emery the surface and put a new seal in like Code58 said.....?
Good luck
Salim
Good luck
Salim
