Engine Check Light = $1200?
Old Jan 7, 2008 | 06:28 PM
Lexmex's Avatar
Lexmex
They are likely running the gambit by the book. I checked in volume 1 of my service manual and basically they ran through the gauntlet of tests for each fo the codes. What would have been better is once they located the problem, they should have replaced part, and if codes didn't come back on, then stop right there instead of checking every last thing. MAF should have been the first thing on the P0171.
I knew back on Dec. 9 when I got a flat P0171 (without a separate pending code) that highly likely the MAF was the issue and it sure was as I replaced it with another. I get a MAF issue sometimes (with the now even crappier gas available here) when I have a very low fuel level, but the pending code is a giveway it is just a temporary sensor issue.
Old Jan 7, 2008 | 09:00 PM
salimshah's Avatar
salimshah
25 Year Member
Originally Posted by 19psi
in those cases, the dealer would have been cheaper. they would have charged an two hours total for diag. time, as they have seen those problems many times. then you would have had .5 hour labor to r&r the mass air sensor and probably another hour for the charcoal canister.
so 3.5 hours total plus parts at the dealer.
private shops are cheaper for stuff like brakes, cv joints and other mechanicals but for electronic diag work, the dealer is usually the btter deal.
I whole heartedly concur. There are times, it is better to go the expert.
Salim
Old Mar 31, 2008 | 06:56 PM
Rizwan's Avatar
Rizwan
Originally Posted by Mut
My 1999 RX300's engine check light turned on recently, and I went to a shop that specializes only in Lexus vehicles. Being unfamiliar and ignorant about car maintenance and repair, I gave the go ahead to start running the tests and look for the problem even though the estimate I received for the absolute worst case scenario was $1200. Well, from all of the mumble jumble I was told, something was wrong with the EVAP and they had to look at each sensor to see if they were giving the right readings. Two codes popped up (forgot which ones).
By the way, I didn't understand much of what they were saying so my post might sound like they were being vague when I'm trying to repeat it.
Apparently, the sensor on the charcoal canister is completely dead. The only way to fix this is to replace the sensor, but the sensor isn't sold separately. The Charcoal canister will cost me $541 to replace. I saw them do the test in front of me so I guess I know it doesn't work, but I don't know if the sensor isn't sold separately.
Also, a long, long, long time ago the cabin air filter was not put back when it was in for maintenance. Some time back, a CD fell in that empty area and got shredded on the air filter. It made some weird noise so I turned the engine off and removed all the pieces. Or I thought I did but one the mechanics pulled out a small shard of the shiny disc. Could this have been an issue?
They had to drop the gas tank and the glove box for checking all of the sensors. This is what's eating up the labor cost.
Either way, one of the codes is fixable with a new charcoal canister. They told me the repair was about 90% finished. So far the bill is at $1024. That's $483 worth of labor the mentioned above. I believe I got ripped off with the labor charge since they "worked on it for 5 hours" or however long. Does it take this long? Is this even normal to cost this much?
This is my first time dealing with an auto mechanic and I understand that I didn't really do my research and go about it the best way possible, but my questions is: how badly am I getting ripped off? When I get the codes, I'll post them for a more accurate estimate. I live in Santa Barbara, CA, which is part of Central California.
P.S. As a bonus, my stupidity lead me to go to Jiffy Lube a few times, which turned out to be a huge mistake since the guy told me the car had the wrong type of oil in it.
This is covered under toyota lexus extended warranty , it should have been done free of cost. this warranty is extended to 14 years or 150K as stated in "bulletin # PRO03-13 DATED 11/06/2003 " . MOST OF THE LEXUS DEALERS DONT KNOW ABOUT IT AND WILL CHARGE YOU. Following things are 100% covered Evap canister, Evap sys pressure sensor, fuel cap, Fuel Tank, Fuel tank filter neck, Purge Valve , Tank Vapor line, Three way valve, or "Any other parts or components excluding any maintenance parts between the fuel tank and the intake manifold (but not including the intake manifold) designed to contain or conduct fuel vapor from fuel system.
If you have already paid for this then call lexus . They will reimburse you full cost of these repairs. I am having the same problem however i pulled out the copy of the lawsuit that can be obtained from epa website. I am sitting infront of this Warranty Procedure Bulletin , it covers vehicles 1996 through early 1998. GET YOUR MONEY BACK. ALL OF IT !!!
Old Apr 1, 2008 | 07:31 AM
mikey00's Avatar
mikey00
"it covers vehicles 1996 through early 1998"
Is this possibly a typo or is it really "early 1998"? If so your post really does not pertain to a 1999 RX.
robertog11
Nov 6, 2018 11:07 AM
uneek78
Mar 11, 2016 10:45 AM
throw
Jan 22, 2016 04:29 PM
ivie08
Aug 21, 2010 10:24 PM
oper026
GS - 1st Gen (1993-1997)
Feb 12, 2010 11:06 AM
