Brake question
Old Aug 6, 2007 | 08:26 PM
bkim's Avatar
bkim
Default Brake question
I changed out all of my pads to ceramic a while ago. When changing pads I did not re-install the shims. The were stuck so well to the old pads that I could not tell that they were shims until I looked at them very closely later. Anyhow, they have worked well and never made any noise, but since I changed them out it feels like the brakes may be dragging a little on the rotors while I am driving. It feels like I am riding the brakes slightly. Could this have anything to do with the missing shims? Do they serve any purpose other than noise management?
Old Aug 6, 2007 | 10:26 PM
salimshah's Avatar
salimshah
25 Year Member
They also spread the force a bit more evenly and would prevent pitting/corrosion between the slave piston abd the pad. The other is the noise.
IMHO they would not change the braking, but are part of the system and affect the longevity of the setup. I would put them on the new pads.
The release of pads depends upon the run-out (side to side play) in the rotor and how quickly the fluid travels back up to the master cylinder. Till the pads move back expect some braking action.
Did you bleed or purge old fluid out of the line?
Any scratches/gouges on the slave cylinder wall?
Salim
2010ISF
IS F (2008-2014)
17
Jul 21, 2015 03:54 PM
nysimonsez
Suspension and Brakes
Oct 25, 2010 06:20 PM
Mike_TX
Jun 22, 2008 12:08 PM
1995LS400
Oct 27, 2007 01:12 PM
95SC400
Oct 25, 2002 01:30 AM
