Brake pad changed, aftermath???
Old Mar 7, 2007 | 08:06 AM
p1fcl01's Avatar
p1fcl01
Originally Posted by salimshah
It is worth while to purge the old fluid out. It is part of regualr maintenance. The process is similar to bleeding but you get your work done lot quicker.
Hope this helps.
Salim
Can you explaint the difference between purge and bleed and why it quicker to purge?
Thanks
Old Mar 7, 2007 | 09:58 AM
salimshah's Avatar
salimshah
25 Year Member
Bleed for air is a methodical process and may require special equipment when you have ABS & VSC. While discarding the fluid, you can be at any wheel.
I am reluctant to write the procedure how to bleed brakes. I am not willing to give folks a rope by which they can potentially hang them selves with.
My advice...
If you dont know the procedure already, get professional help. This is something you should not learn as you go. Have some one to show you.
Salim
Old Mar 7, 2007 | 10:52 AM
TunedRX300's Avatar
TunedRX300
I have done the traditional "pump the pedal, hold, and open the valve" method for my Acura and Lexus, both are ABS. Works like a charm.
Purge is sucking fluid out, bleeding is to use pressure to force fluid out.
If you have not done it, take it to a brake shop.
Old Mar 7, 2007 | 12:18 PM
p1fcl01's Avatar
p1fcl01
Yes, will do. Thanks
abaitedcat
Suspension and Brakes
Mar 1, 2019 02:28 PM
Mattkz
Jan 11, 2019 09:20 AM
Wallander
RX - 3rd Gen (2010-2015)
Jan 20, 2017 10:11 AM
KtIS
Jun 23, 2015 01:44 PM
en11871
Jan 22, 2008 03:53 PM
