Check Engine Light VSC light
Old Jan 5, 2007 | 07:28 PM
woods's Avatar
woods
Exclamation Check Engine Light VSC light
Greetings,
The check engine light and VCS light have been on and off lately. Advanced Auto checked the codes tonight.
P1130
P1150
Based on recent research the codes indicate Air Fuel Ratio Sensor Circuit Range/Performance malfunctions in Bank 1 Sensor 1 and Bank 2 Sensor 1.
My questions are: What next? Replace Air/Fuel Sensor?
Thanks!
Old Jan 6, 2007 | 07:44 AM
Lexmex's Avatar
Lexmex
Originally Posted by woods
Greetings,
P1130
P1150
Thanks!
Woods,
Thanks for bringing the codes.
The P1130/P1150 are indeed just what you mentioned.
There are 3 possible trouble areas:
1. An open/short in the A/F sensor
2. The A/F sensor itself
3. The ECM (doubtful)
From it coming on/off there could be something loose on one of the two A/F sensors, there is a bad A/F sensor, or there are anomolies in the climate/air that are causing this.
You need to do a few things.
1. Pull the EFI Fuse AND the negative and positive battery cables as we have mentioned before. You can put the EFI fuse back in. Wait 30 minutes. That should kill any juice in the capacitors.
2. Take it for 1 hour drive, 50/50 mix of highway/city if possible.
3. See if light comes on or not.
4. If the light comes back on again, you will need to verify which of the 2 A/F sensors is the culprit. Now I am not sure what OBDII readers Autozone has been using, but many mechanics (Lexus/Toyota definitely have them but I don't want you to spend extra $$$) have readers that will analyze the 2 oxygen sensors to see what the readings are and can determine which sensor is the culprit. Some higher end OBDII readers can not only tell you what the error code is, but also which sensor is the culprit.
From general experience I have seen on this forum and in what I have read, the usual suspect is the rear sensor behind the engine block, Bank 1, Sensor 1.
Old Jan 6, 2007 | 10:26 AM
woods's Avatar
woods
Thanks! Light went out today. Climate changed from wet/humid to dry. I will check the A/F sensors for a loose connection and reset the codes. I will get back later. Anything with it being in Bank 1 and Bank2.
Woods
Old Jan 6, 2007 | 06:07 PM
anulex's Avatar
anulex
dude it going to come right bank. be prepared to spend $400 on the replacing the two a/f sensors
Old Jan 7, 2007 | 06:17 AM
woods's Avatar
woods
thanks! Can anyone tell me what the toyota part number is? I checked at Adavanced Auto yesterday. All they sale is the bosch.
Woods
Old Jan 7, 2007 | 08:05 AM
Lexmex's Avatar
Lexmex
Woods
Woods,
Go to a place like www.oxygensensors.com and plug in the information for your RX300. They list the Denso sensors (these are the ones you want) and you need the ones that "sensor located in the front manifold/exhaust pipe before catalyst - two required). The other sensor listed is for the one after the catalytic converter below the vehicle, which you don't want.
robertog11
Nov 6, 2018 11:07 AM
wzwz8221
Dec 16, 2012 05:10 PM
Saurabh
Nov 11, 2009 05:37 PM
desantura
12
Jan 19, 2009 09:33 AM
yoshi
Nov 6, 2007 10:45 AM
