intro - shopping for a 300
Old Sep 10, 2006 | 07:11 AM
euclid42's Avatar
euclid42
Default intro - shopping for a 300
Hi, just an intro.
My wife and I are going to be getting rid of our 2000 VW Passat AWD to be replaced by a 300 soon. We have both enjoyed the info from your forum so far, and I'm looking forward to becoming regulars. I'm a mod over on ih8mud.com which is the LandCruiser forum so I know how helpful the community can be.
Since my LandCruiser has 250K miles on it, we are familiar with how well built the 300 is, we like the looks of it, and we also really want an AWD vehicle. The extra space is needed for our 1 year old.
We will be looking for a 99 - 01. We aren't that worried about miles.
Our color choices are:
woodland pearl
indigo ink pearl
black onyx
twilight blue pearl
millennium silver metalic
graphite gray pearl
We would prefer the gray interior.
We aren’t in a hurry at all, so we will be able to wait till we find the perfect car. Well kept maintenance with records to proove it is also a requirement.
I haven't run across a thread or site with a maintance schedule. Any links? Timing belt at 90k, right?
Any leads you would like to forward would be appreciated - euclid42@gmail.com
Old Sep 10, 2006 | 08:26 AM
Tammy's Avatar
Tammy
Primarily, in the 99-01 3.0 liter Toyota/Lexus engines, if the oil was not changed regularly it had a tendency to sludge. Insure you have good maintenance records with your purchase. Removing the valve cover or oil pan is needed to inspect the internals for the jelly like substance.
Secondly, with an all wheel drive, the transmission fluid needs servicing every thirty thousand miles. This should also be documented with owner using the Toyota type IV transmission fluid. The ATF fluid color should be cherry red in color, without a tint of brown.
The chassis should be inspected for tears or cuts in the four axle drive shaft CV joint boots, two CVs per axle. The steering rack end boots also need inspection for damage or drying of the boot material.
Every thirty thousand miles, all the vehicle fluids should be exchanged. This includes in the AWD, the transmission fluid, brake fluid, power steering fluid, transfer case gear oil, rear differential gear oil and coolant/antifreeze. These services also needed to be documented by receipts with date and mileage.
Timing belt and spark plugs are at 120K miles on the RX.
Old Sep 10, 2006 | 02:30 PM
bob2200's Avatar
bob2200
There used to be a nice maintenance schedule on the ClubLexus web site, but I sure can't find it now, since the web pages were remodeled. Anybody?
Old Sep 11, 2006 | 07:58 PM
Andrax's Avatar
Andrax
The local dealer and independant shop here told me to expect to do the timing belt at 90k...
That will be a fun combined service.
Old Sep 12, 2006 | 08:48 AM
euclid42's Avatar
euclid42
Good info so far. From other places I'm finding I should be cautious when it comes to a whineing transmission, and watch for the exaust leak that is typical.
Old Sep 12, 2006 | 02:50 PM
miltonlin's Avatar
miltonlin
Hi euclid42
I'd upload the manual here, but the pdf is just a little too large .
The owner's maintenance manual is ambiguous at times. I called Lexus once asking them for clarification and they told me that my dealer is the best place to get an accurate assessment of the vehicle and what it needs (so much help that was). Sure that makes sense.
The manual is misleading if you don't know the history/possible troublespots of the vehicle or similar vehicles:
1. 5K oil/filter service interval (dusty, towing, short trips <5mi) or 7.5K service interval. The 1mzfe engine can sludge under the right conditions, so that should rule out the 7.5K oil change interval. Unless you know what's going on in there (oil analysis), I wouldn't take it farther than 5K. If the owner used synthetic, that would be a plus.
2. I think the recommendation to inspect brake linings, pads, body bolts at 5/7.5K intervals is excessive and would feel fine at 30K.
3. The inspections for the fluids simply should be to changed to replace the fluids. The tranny is very hard working. If doing a drain/fill, I would do that every 15K. If doing flush, every 30k. Lexus dealerships near me don't have a flush machine, even though "flush transmission" appears under what they did on the bill. How's that for misleading
4. No mention of cleaning/servicing the throttle body. I would do that every 30K. If your IAC valve gets clogged up, you might be stuck somewhere and have to have it towed, and then looking at several hundreds in repair.
That manual says the timing belt for my 2000RX says should be changed at 90K. But timing belt can als be changed out earlier if it is old, even if you have not reached the mileage interval.
Good luck shopping for an RX.
I love the first generation RX's.
yeo34th
Jun 27, 2019 02:01 PM
Seeker4
RX - 3rd Gen (2010-2015)
Jan 22, 2014 10:04 PM
anonymous4
Dec 10, 2008 03:10 PM
RomeyG
Jul 31, 2006 11:42 PM
BlvdKing
Jan 27, 2003 06:44 PM
