timeing belt
Old Feb 6, 2006 | 07:15 AM
slick20's Avatar
slick20
Default timeing belt
interested in replaceing the timeing belt on my 99rx300. how hard is this job?any info would be greatly appericated. thanks.
Old Feb 6, 2006 | 09:30 AM
Tammy's Avatar
Tammy
Not for the young or weak at heart..
That said, when someone asks on this type of job, my first question "What is your tool set and mind set"? Are you a trained auto mechanic and have the skill set? This is much more than removing bolts and replacing them. There are torque specs for various bolt sizes, critical in an aluminum engine. Different tools for the various tasks to be performed. Does this bolt need anti-seize or thread locker?
Then there the alignment and timing proceedures for removing and installing the belt. One may reference the Camry V6 proceedures for advice. Many also replace the belt idlers with bearings and water pump concurrently with the timing belt. I would if the coolant hasn't been changed every 30K miles.
If I were to advise, take it to toyota for a price to install. At least, to an independant toyota shop that has performed the task many times. A poor job will haunt you.
Old Feb 6, 2006 | 09:59 AM
Lexmex's Avatar
Lexmex
Also think about the fact it might be in your interest to change the water pump at this time, if it is about 90K.
Old Feb 6, 2006 | 10:23 AM
salimshah's Avatar
salimshah
25 Year Member
Physical ability/limitation is also another factor. I found that my hands were to big to fit between the wheel well and the face of the engine on a transverse mount in-line4. RX is a transverse mount v6. So not only visualize but try to get your hand with tool(s) physically in there.
The other factor is that if the timing belt is being replaced for the first time, although all bolts are tightened to spec, but since they get a varnish coat, it is diffcult to get them going.
Salim
Old Feb 6, 2006 | 10:55 AM
slick20's Avatar
slick20
while i am a skilled diy and have many tools, you guys do bring up some vaild points. i did forget about torque specs,tension pully water pump all items which should be addressed when accessing the timeing belt.dont think i will take this on my shelf.but thanks for all the replies and i will be looking forwared to reading all the great info you guys provide in these forums. thanks again!
Old Feb 6, 2006 | 11:14 AM
Lexmex's Avatar
Lexmex
My cousin installed my URD pulley in about 30 minutes or so that required taking off the timing belt. He did not even have to open the service manual. Literally, took of the front, right tire and went to work. He had all the tools and a month later, no issues whatsoever. It's doable.
Old Feb 9, 2006 | 09:51 AM
right RX's Avatar
right RX
Default Timing Belt/Engine Question
I recently purchased a 2001 RX and upon noticing the work done to it at Lexus dealers, I discovered that it had a short block replaced around 55k. My first question is: Did the dealer mechanics change the timing belt when they replaced the short block?
and secondly, is the RX engine a "non-interfering" one in that if the timing belt does break, the engine won't immediately be destroyed while driving?
Thanks for the help
Old Feb 9, 2006 | 11:57 AM
Lexmex's Avatar
Lexmex
Thanks for the help
Non-interference, not sure about the engine block question.
Old Feb 22, 2006 | 02:01 PM
AudioMan's Avatar
AudioMan
What kind of prices would one be looking at for a new timining belt and water pump? My wife's 99 RX is at 103,XXX and is about due. Thanks.
Old Mar 1, 2006 | 06:43 AM
rpete33's Avatar
rpete33
Default RX300 Timing Belt
My good friend ,who is the service manager at a Toyota dealership, informed me that he has NEVER had a timing belt break on a V-6 Toyota engine. The RX300 is the same engine as a Camry. He told me that they made the timing belts too good and they may last forever!!
What do you think?
Old Mar 1, 2006 | 07:09 AM
JZA80MHU38's Avatar
JZA80MHU38
I won't bet on that. A $800 job (including water pump) may save you thousands of dollars from rebuilding the engine if the belt did break, and not to mention about leaving you strand on the road in the middle of no where.
Old Mar 1, 2006 | 10:02 AM
Lexmex's Avatar
Lexmex
My cousin took out the front belts (PS and Generator belts) and also the timing belts (with the URD 1MZFE pulley change) to see any ill effects after 1 year (I had the belt changed at about 84K). Nothing...and he realigned it, put in the pulley and that was it.
I have heard belts going up to 150K miles before changing. I would think that the PS or Generator belts could break should some road debris kick up in there, but very rare and Mexico would be one of the most likely places, however the timing belts are in a pretty well protected area.
Now, supercharger belts...those do break.
Old Mar 1, 2006 | 02:18 PM
mikey00's Avatar
mikey00
What do you think?
I have heard the same comment from experienced Toyota techs. Even if it does break, it is a non-interference engine and will not have any damage done. Just major inconvenience. I had my belt done at a Toyota dealer for $399 at 90K just for piece of mind.
Old Mar 14, 2006 | 02:10 PM
neilmian's Avatar
neilmian
I just replaced the Timing belt on my 99 AWD. It took me 4 hours and I was able to replace the Water pump, tensioner, tensioner bearing and idler bearing all with oem parts for the cost of parts from www.partznet.com (Total of $300.00). The most difficult part of the whole project is removing the Crankshaft pulley. Luckily my 12v impact wrench zipped it right off. The rest of the job was fairly easy. This was my 1st timing belt replacement on a V6 engine.
Old Mar 14, 2006 | 02:18 PM
Lexmex's Avatar
Lexmex
Glad to hear you DIY
That impact wrench is the real key to making the job a lot easier.
