quick question
Old Jan 18, 2006 | 01:01 AM
mr. aristo's Avatar
mr. aristo
Default quick question
is the rx300 windshield wiper reservoir in some secret hidden place? my girl has a 2000 and i can't find it anywhere... when i look in my engine bay its just chillin in plain view... where is this located or maybe some just took it out
Old Jan 18, 2006 | 03:36 AM
rxdriver's Avatar
rxdriver
All you're going to see is the black cap with the universal symbol for windshield washers on top of a filler tube. The reservoir itself is buried down in the engine compartment. If I recall correctly, the cap is right behind the headlight on the passenger side of the engine compartment.
There is only one up front - it supplies both the front and the rear wipers.
Old Jan 18, 2006 | 06:28 AM
salimshah's Avatar
salimshah
25 Year Member
There is only ONE resorvoir, which is shared by the front and rear washer. The rear has a longer tube to travel and if not used, can hold air. It is imperitive that the right washer fluid (has anti-freeze and detergent quality to prevent blockage) is used and the tubes are purged (used) frequently.
If not used recently, you may have to run it for a while. If there is blockage you may have to open up panels and blow the pipe clear.
Salim
Old Jan 18, 2006 | 07:25 AM
Lexmex's Avatar
Lexmex
On the front bumper passenger side there is a small air inlet. If you look inside you can see some of the white plastic of the bottom of the reservoir. If you have a tranny cooler it would be just below.
funcrusher
Feb 15, 2011 09:01 AM
Capirato
GX - 1st Gen (2003-2009)
12
Dec 10, 2007 10:35 AM
rhinnard
Oct 12, 2006 04:51 PM
tmf2004
Maintenance
18
Sep 9, 2005 12:10 PM
