Electronic compass - help
Old Aug 17, 2005 | 10:02 AM
rx300mm's Avatar
rx300mm
Default Electronic compass - help
In my RX300 (2001) the electronic compass on the rearview mirror is not working anymore. It is pointing only "E" , if I tilt to one side it resets "--" then it may point to "NE" .Does anyone know if this is battery operated, needs replacing, etc.
I don't normally use it for directions but now that I know its pointing wrong direction it has become somewhat annoying.
Thx
Old Aug 17, 2005 | 05:43 PM
rxdriver's Avatar
rxdriver
To fix this, check in your manual for a section on "compass calibration". It describes the process step by step. Essentially, what you do is put the compass in calibration mode, and then drive around in a 360 degree circle. Obviously, you need to go to a parking lot or some other place where you can do this without stopping or running into something.
The compass itself is powered by the main vehicle battery. It doesn't have separate batteries. It can be confused by strong magentic fields, and re-calibrating solves the problem. However, if other electronics start acting strange as well, that's an early signal that it's time to replace the battery. If the battery has never been replaced, 4 years is more than enough for one battery.
Old Aug 21, 2005 | 07:15 PM
rx300mm's Avatar
rx300mm
Rxdriver,
I followed the "compass calibration" instructions (mostly what you mentioned) from the RX300 manual and it is working fine. Thx
kodi2011
Jan 26, 2018 02:24 PM
drgerry
Aug 21, 2016 05:48 PM
ssis300
IS F (2008-2014)
17
Feb 13, 2016 02:19 PM
DRVIII
Feb 11, 2012 11:42 PM
Dx3
Mar 3, 2008 05:36 AM
