TSB RX300 Front Brake Squel
Old Feb 28, 2005 | 01:24 PM
toy4two's Avatar
toy4two
Default TSB RX300 Front Brake Squel
Component Description:
2. SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTSISC Bulletin Number: BR00102
Bulletin Date: MAR 2003
Vehicle: 2000 Lexus RX 300
Summary:
INFORMATION ON REDUCING FRONT BRAKE SQUEAL NOISE. *TT
Anyone know whats in it?
Old Feb 28, 2005 | 02:34 PM
Tammy's Avatar
Tammy
Technical Service Information Bulletin BR001-02 (March 22,2002) Front Brake Squeal Noise 99-01 RX300 - Refers to the new shim kit and pad support plates. It applies up to a cutoff VIN range depending on 2WD or AWD. Additionally new pads or disks may also be installed, if the VIN fits. Your Lexus dealer should be able to help you further...
Old Mar 2, 2005 | 07:11 AM
mikey00's Avatar
mikey00
Where are you guys getting the TSB info? I checked AllData and TSB BR001-02 only pertains to 2002 RX. Lexus changed the front brake pad design that year and I suspect it has something to do with that.
Old Mar 2, 2005 | 10:37 AM
TunedRX300's Avatar
TunedRX300
I used to have rusted rotors that sing, I can really hear them when coasting at 5-10mph.
I replaced with Brembo OE replacement front rotors and Akebono ceramic pads for 5 months and not a single squeal, much better stopping with these superior products.
When I replace my rear pads and rotors, I noticed OEM semi-metallic brake dusts caused corrosion on alloy wheels.
me_ccie
Dec 8, 2011 05:57 PM
neko82
Suspension and Brakes
Dec 23, 2006 11:51 AM
Scotty99
Dec 16, 2006 07:25 AM
vinster29
Maintenance
Aug 2, 2005 11:33 AM
