Rear main seal
I have a 2000 RX with 83K on it. I have been noticing a small oil spot in my garage for the last few weeks. I was getting my oil changed at a Jiffy Lube this weekend and the mechanic identified the leak as the rear main. I did a search on CL and only found 2 posts. Has anyone else had this problem? How much is this going to cost? Thanks in advance for your replies.
My wife's 2000 RX 300, FWD [ 48,000 miles ] was in the dealer's shop about a month ago for replacement of the rear main oil seal. The service director said it doesn't happen often, and usually occurs in the AWD models. Her car was covered under the Certified Warranty, but while looking at the repair order I'd say that the cost to a customer would be in the $500.00 range. [ about 5 hours labor for a FWD model ] Good luck!
Originally posted by KeysRx300
Was wondering if this repair would be covered by the 70K mile engine warranty?
It would be interesting to see if the 70k warranty would apply.
Dropped it off this morning. Obviously they have not looked at it yet, but they said it was covered under the extended warranty ( I bought it used). I will let you guys know what happens.
On another note; loaner car is a new 330. No long trips in it yet, just a 5 mile trip to the office. Can't say I am terribly impressed....I was expecting more. It is probably not fair to issue an opinion yet with very limited driving, but my first impression is that it is noticeably noisier (engine and road noise) and does not seem like it rides as good. It also seems to shift gears a lot more with noticeable shift jerks. Just does not seem as smooth and quiet as a Lexus should be.
Originally posted by Fern
Rear main seal sounds like powertrain to me!
Why does it cost twice as much to replace the rear main seal on an RX than it does a Toyota Highlander when the engine and transmission are EXACTLY the same units? [ FWD or AWD ] What a $CREW JOB !
Had my rear main seal replaced in my 99 RX about a 4 months ago. I found out through lexusownersclub.com that it was more common that I had thought...and that the original seal wasn't made so well....but that the new ones are much better. I got lucky and had an extended warranty or it would have run me about $1100.00.
IronSeven7
RX - 4th Gen (2016-2022)
Dec 26, 2018 11:19 PM
