Air bag warning light ??
Old Feb 19, 2026 | 11:46 PM
jonas's RX's Avatar
jonas's RX
Default Air bag warning light ??
Quick Q to the RX300 owners out there
Does your airbag warning light go off immediately after you start the car or does it take 6 seconds before going off? My RX330 goes off immediately
Old Feb 20, 2026 | 07:51 AM
salimshah's Avatar
salimshah
25 Year Member
Worrying too much.
The self test during initial start procedure is to verify the "idiot lights" are not blown. In case of a problem they have a chance of lighting up. Now if some one has jury-rigged the wiring then we have another issue.
I do not recommend it, but if any sensor is disconnected and the vehicle is turned on, the ECU will get in stuck-on fail mode. Reason I don't recommend it is that to reset the light, you will most likely need to go to the dealer.
Just leave it alone ... At most connect to a smart (advanced) OBDII reader and look for Bxxxx codes.
Salim
bigkuujo
Jan 4, 2025 10:13 PM
Rezasaba
IS C
Jul 1, 2021 07:54 PM
ohiois350
Feb 13, 2018 07:12 PM
madunix
IS - 1st Gen (2001-2005)
Aug 4, 2013 11:31 AM
aznKewlguy
Sep 7, 2011 06:08 PM
