Fuel pump
Old Feb 4, 2026 | 03:32 PM
MWALDO's Avatar
MWALDO
1st Gear
Default Fuel pump
I ordered a market fuel pump in order.The one that it called for and got it, and it is a 1/2 an inch too tall as anyone else running into this problem.And is there a fix for it
Old Feb 5, 2026 | 09:50 AM
Fit1too's Avatar
Fit1too
Rockauto is showing a DENSO 9510002 as a replacement unit. Never had to replace mine, hopefully someone can guide you better on that.
Old Feb 5, 2026 | 10:05 AM
salimshah's Avatar
salimshah
25 Year Member
Fuel pump can fail too, but it is pretty robust as it does not run all the time, but first gen is aging.
Just because it does not run all the time, people can misdiagnose it as broken. There is built in safety, where the pump is disabled if the engine is not running and a special software control to prime up the fuel system as the key is detected. A conclusive test is to measure pressure in the fuel line and flow. [you will need the pressure spec and flow spec]
Another way is to remove the key and lock the doors. Physically move away the key from the vehicle. Disconnect the fuel line [there is a disconnect where the fuel line comes up in the engine compartment [body to engine]. Prepare safety as raw fuel will be pumped up form the line you just opened. Bring the key near and open the lock and stick the key in the ignition and pump should start.
I would shy away from aftermarket pumps as you are not guaranteed pressure and flow.
Salim
peterls
Nov 22, 2024 11:39 AM
Alexander457
IS - 1st Gen (2001-2005)
Nov 3, 2024 09:27 PM
YODAONE
Apr 17, 2021 03:41 AM
cino78h
SC400 / 300 Classifieds
Feb 10, 2007 08:49 AM
