oscillating illumination...Battery/Alternator problems?
Old Dec 5, 2003 | 01:09 PM
rcnv's Avatar
rcnv
Default oscillating illumination...Battery/Alternator problems?
I am having this issue with our RX300
when the car is started and without turning on the headlights or the radio (only the auxilliary lights: side marker, licence plates, tailight) or when we turn on the interior dome light. we can perceive that there is some flickering/oscillating. The illumination is not stable, something like if the current was changing.
if it turn on the headlights, i can perceive them oscillating when i contrast the lights in a dark area. if i turn on the heater and the radio, it seems not to make it worst or go away.
Any ideas, I am vaguely speculating that it could be either the alternator about going bad or something with a voltage regulator?
So far we had no troubles starting, we drive the rx on the weekends so pretty much we used it 2 to 4 times a month. it currently has 71000 mi
thank you
RCNV
Old Dec 5, 2003 | 09:45 PM
SteveH's Avatar
SteveH
I have a 1999 with 40K miles on it and noticed the "oscillating illumination" which by the way is an excellant description of the problem and was told by the dealers service writers and technicians that it was normal for this type of lexus. I would like to here if the years after mine still have the same problem and if anyone has ever come up with a fix? or did they reengineer something, if so what it was to get it fixed and if the fix is backward compatible??
Old Dec 6, 2003 | 04:42 AM
mooretorque's Avatar
mooretorque
Talking
This also may be the first sign that your battery is going south. If this is only noticeable at idle and immediately at step off with a perceptible brightening of the lights and display, it can mean that the battery is no longer able to provide enough support for all the electrical demands when the engine is merely idling.
We had similar issues this past summer and, as a former pump jockey, I should have picked up on it sooner. The V6 lights off so quickly that the old symptom of slower cranking by the starter motor just isn't apparent until the very end of the line. Your clock in the display may start to lose its setting, too.
Can't complain, though. The original battery lasted more than 5.5 years (which is about 1.5 years longer than you can usually expect). Alternator or VR also a possibility, but battery is most likely (and cheapest); get it load tested before moving on to the pricier stuff!!!
Old Dec 6, 2003 | 10:06 AM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
I noticed the same quick oscillation of the lights myself about a year ago. It was the most obvious to me in the dark with the dome light one. It doesn't seem to go away...ever; not even while driving. Must be in the design of the electrical system
Old Dec 6, 2003 | 01:41 PM
rcnv's Avatar
rcnv
you guys are experiencing exactly what we are experiencing? is this another 99-00 problem?
RCNV
Old Dec 8, 2003 | 12:05 PM
rcnv's Avatar
rcnv
I tried the cleaning the battery contacts, but no money.
The problem is still there, and it gets kind of anoying when it is very dark, specially on the dome light..
Any more ideas?
thanks
RCNV
RRocket
Jul 7, 2013 05:04 PM
silkiechic
Jan 30, 2010 11:29 PM
peterstacy
Jan 16, 2008 06:16 PM
SC3005SPD1
Aug 9, 2005 02:16 PM
mach_y
Jul 29, 2001 06:34 PM
