9005 LEDs for DRL
Old May 20, 2024 | 01:48 AM
e21pilot's Avatar
e21pilot
Default 9005 LEDs for DRL
I recently had a 9005 halogen bulb burn out on the driver's side DRL location and decided to replace both with a set 9005 LEDs I got at the local parts store.
The LEDs installed fine but they won't light up. I know there is power going to them because I retested the connections with the one halogen bulb that worked.
Any one have an idea why these LEDs won't light up? Maybe I am missing something.
Old May 21, 2024 | 06:14 AM
salimshah's Avatar
salimshah
25 Year Member
For RX300, DRL are actually high beams connected in series through relays.
Check if your LEDs will work with 6v. Also check the wiring [circuit diagram] to make sure the + and - are properly fed to LED [LEDs require the proper +/- connection].
Lastly the LEDs give you whiter light but not necessarily better visibility. If you are not satisfied with light & visibility you can try ultra bright Halogens. The reflector in RX300 and its focus is shaped for halogen light bulbs.
Salim
johnnylt
Oct 18, 2018 11:32 AM
triplecore
Dec 3, 2012 03:11 PM
s4play
IS F (2008-2014)
Jul 29, 2009 07:59 AM
KevMMA
Lighting
Oct 3, 2008 02:55 PM
Zanorath
Lighting
Mar 27, 2008 07:04 AM
