Vapor pressure sensor different
Old Dec 5, 2023 | 02:07 PM
Brody1236's Avatar
Brody1236
3rd Gear
Default Vapor pressure sensor different
I'm replacing a vapor canister assembly on a 99 rx300. I notice the original one had some sort of check valve spliced into the line. The vapor pressure sensor is different too. The original had a single nipple with a line going to it, the new one has a second nipple right by it. Any guidance how how to hook up the new one?
Check valve T'd into it.
Old Dec 5, 2023 | 03:19 PM
maxSteel's Avatar
maxSteel
Is it the right canister? From my notes
  • On my 1999 the original was 77740-48010
  • As per TSB EG001-99 from April 1999 it was replaced by 77740-48030
  • Some parts sites doing a VIN lookup said it was 77740-48011
I used the 77740-48011
Did you do the canister diagnostic before ordering a replacement?
Old Dec 5, 2023 | 08:34 PM
Brody1236's Avatar
Brody1236
3rd Gear
According to the dealership, that is the right canister, and it appears to all be correct. The only thing that is different is the vapor pressure sensor. However, the part number off the old one was superceded by the new one, but the physical design is different. I also went to a part store and had them cross reference the original one, and the one they pulled up looked like the new version.
And that is what has me thrown off. Do i have to transplant the check valve and T off the old one? Or instead of the vehicle connecting to that blue check valve, does it connect to the 2nd nipple on that new vapor pressure sensor? (The old one has one nipple, the new one has two)
Old Dec 5, 2023 | 08:40 PM
Brody1236's Avatar
Brody1236
3rd Gear
Old design
New design
Old Dec 6, 2023 | 05:29 AM
maxSteel's Avatar
maxSteel
I don't recall any issues when I changed mine. Pretty sure it was an exact replacement.
I don't understand the old valve, with a single nipple. If that's the input where is the output? Has to be just open air
If that's the case a direct swap would probably be just connect your single tube to one of the nipples, and leave the other one open.
EDIT: My bad, it's not a VSV. Maybe you just need to cap one of the nipples.
Bodbeli
UX Models (2019-present)
Sep 17, 2025 12:44 PM
guesswh0
Build Threads
Oct 24, 2024 09:56 AM
Raven01750
Jun 15, 2023 08:36 PM
