Black Pearl Emblems
Old Feb 21, 2022 | 06:11 PM
jnadz's Avatar
jnadz
Default Black Pearl Emblems
Has anyone found a black pearl emblem set for the 2020+ models? The rear emblem is different on 2020+ cars. Not sure if the front is different as well.
Old Feb 22, 2022 | 01:36 PM
nigel821's Avatar
nigel821
You should be able to swap the rear emblem no problem since that didn't change in shape or size. IE: Pre-face lift RCF's have changed to the newer updated face lifted rear badge. The front, not entirely sure about since the sensors are there behind the bad. If you swap out the front emblem and you have radar cruise you run the risk of it not working properly.
-Nigel
Old Feb 22, 2022 | 03:24 PM
3ISRC's Avatar
3ISRC
Get the rear, it's an easy swap it will match the front.
Old Feb 22, 2022 | 06:38 PM
jnadz's Avatar
jnadz
The only black pearl rear badge I’ve seen is the one that is hollow. I have wrapped my car in satin PPF and they cut around the emblem, so if I switch to an open emblem you will see gloss paint in the middle. May not Evan notice or might look ok that way but just not sure. Do you know of a black pearl rear emblem that has the mesh or something solid behind it?
CobraGSF
Apr 11, 2014 09:42 AM
Jasbmo
Maintenance
Oct 28, 2006 01:52 PM
AZDesertGS
Aug 16, 2006 12:50 PM
clambros
Jul 11, 2006 09:56 AM
