Hot water hitting exhaust and causing steam
Old Aug 6, 2021 | 07:47 PM
Ab175's Avatar
Ab175
Default Hot water hitting exhaust and causing steam
When I got home today and shut off the car, a bunch of hot water kept hitting the exhaust and causing a hissing noise and a little steam cloud. It is an aftermarket invidia carback exhaust that I had installed 2 days ago. It never used to do this so I imagine this has something to do with that install. I believe it is just AC condensation but I still don't know how it's getting to the exhaust. I will post a video in which you can hear the hissing shortly once I figure out the format, any help or ideas on what could be causing this are much appreciated.
Old Aug 7, 2021 | 07:52 AM
brendanf's Avatar
brendanf
It is most likely AC condensate and if so, honestly I wouldn’t worry about it.
some days are more humid then others and will generate more condensate.
My only worry would be if you happen to have a valley plate leak and that is what you are hearing dripping on the exhaust.
Other wise I wouldn’t worry about it. It is only water and won’t harm anything
Old Aug 7, 2021 | 04:51 PM
Yri's Avatar
Yri
When coolant burns, oh boy do you smell it. It is one of those smells that instantaneously makes you want to vomit and sing some lonesome blues. It is absolutely horrendous, and not to mention if coolant is dripping that much, there would be a fairly large (if not massive) puddle under the car. As brendanf said, it is most likely just the AC condenser.
AndyL888
RC F (2015-present)
Apr 12, 2019 09:16 AM
Chuckinnj
Aug 2, 2014 10:45 AM
liqinwei26
Feb 27, 2014 02:42 PM
x10civ
RX - 3rd Gen (2010-2015)
Sep 25, 2011 12:53 AM
VegasIS250
Sep 13, 2007 12:52 PM
